Old Man Roger
Palm Coast Florida
Does it hold pressure overnight?
I did put the gauge on it one night, so I didn’t have to do it in the morning, but I don’t remember if it had pressure that morning. I may not have even started that night after putting on the gauge, so it would have been at zero in the morning.
I was more looking to see if it built pressure immediately, and if it would hold pressure for a few minutes, and it did both.
I’ll throw the gauge on it later this morning and see what the pressure does through out the day.
niget2002
Josephine, TX
What make and year is your truck niget?
2022 RAM 2500 Diesel
Quick research shows I'm not the only one to have the 'click no start' issue and have it be the starter. Those people were able to use a jump starter to start their truck too. So I guess it's an electrical issue on the starter and not mechanical.
Still curious about the low voltage on the battery and it not charging over night. Makes me wonder if the electrical issue in the starter causes it to constantly drain the battery? IDK.
NWOhioChevyGuy
Buckeye Hill (Morenci, MI)
Garage has been over run with kitchen remodel supplies and set up since late April. Getting to the home stretch on this, counters get installed this afternoon and flooring later in the week. Then trim and appliances next week.
Last night I modified this original cabinet from 1914 to be reinstalled after the counters are set.
Still have a couple things to finish up on it but coming along as planned.
Wiz02
Southeastern PA
Very cool, I hope that you don't paint it white or gray like the cabinets in everyone's kitchen that I know.
ZRX61
Solar Blight Valley, SoCal
Trimmed the "pre-production" version of the bracket I need to fabricate to hold the front rail of the tonneau cover on the F350 in place. Just need to straighten up the cut, smooth out the saw cuts with a file, drill a hole in it & install a riv-nut in the front bed rail.
Slight PITA as the work mostly has to be done with the cover on the bed, but I get to lay down on the job.
Now I wait for the correct drill bit for the riv-nut to arrive on Thursday.
NWOhioChevyGuy
No paint (other than the interior) the doors have been stripped and stained already in the pictures.
Just a coat of satin poly to add to them. The face frame needs stripped and refinished yet.
The maple in these cabinets is stunning and was harvested from the woods out back so extra care has been taken to preserve what I can and make it fully functional in the new kitchen. I couldn't save the other cabinet from that time period, so I have extra of the maple to fix what was needed on this one.
Magnum440d100
Indiana
Still more and more organizing and putting away.
I didn’t realize how sloppy it was in here.
Luckily I’ll have more time to clean/organize now that some jobs are changing and I’ll be working closer to home.
Just gotta remember “don’t put it down, put it AWAY”
But hey, at least I can walk from workbench to roll up door without going sideways lmao
rcktpwrd
Raleigh, NC
That is an amazing piece! Great to see it being cleaned up and reused! :cool:
rharman
SoCal
Why are you just now telling us about this? It's like the secret cure for the common cold!
Magnum440d100
Indiana
Amazon carb showed up. Put it on and kept fouling plugs. Too big a carb and I didn’t want to mess with jetting just yet.
Took a gamble and ended up cleaning the old carb, and she runs pretty good. Did a bit of mowing in the tall grass, but forgot I wasn’t on my 20hp. This one is 15.5 and didn’t like the tall stuff lol.
Tomorrow after work I’m going to pressure wash it and do another oil change. The oil that came out was gasoline. I think the needle stuck open on the carb and drained into the crankcase.
Still needs the shifter adjusted, and possibly new belts, blades sharpened, and the headlight harness repaired. Then she will be up for sale.
That’ll be tomorrow though. It’s late.
welder4956
Birmingham, AL USA
Not much accomplished today. I started putting the new boots on the steering rack for the Mustang and found the passenger side is a larger diameter than the driver side. Driver side was 1.84" ID and went on fine, but passenger side needs 2.25" ID boot. I spent the rest of the day looking up Ford part numbers and verifying dimensions of the new parts. It seems the passenger side boot has been discontinued by all of the parts manufacturers and MOOG shows the same part number for both sides. I finally found a NOS Ford part on eBay and will have to wait till Monday to put it on. Meanwhile, I will continue cleaning and painting engine parts.
Skyman
Central Maryland
More info!
How does it work? (Yes I should know)
What setting?
I need it...
Ps anyone know how to keep the multimeters leads from failing?
One of the complications when troubleshooting parasitic battery drains on modern vehicles is the delay in the shut-down of interior lamps, accessory bus, etc. When attempting to monitor current on the meter's low-current setting, that delay gets in the way, and the current will pop the low-current fuse in any of my meters if that current exceeds 2 amps.
So I built this rig that allows me to monitor the drain current on the meter's high-current scale, with the shunt switch open, until the delay times out. Then, I close the switch to keep the parasitic current flowing so that it doesn't reactivate the delayed accessory bus when I disconnect my meter and reconnect it on the low-current scale. Once the meter is set up to monitor the drain on the low-current scale, I then open the switch to monitor the parasitic current in milliamps with much better resolution while I try to identify the parasitic culprit.
And, as noted by a previous respondent, there's no substitute for quality meter leads. The cheap **** ones will only frustrate you. Toss 'em and buy good ones with sharp tips and various clip attachments.
WildBill
PNW
Got the front brakes swapped for discs, rebuilt the rear drums with all new parts, replaced all the flexible lines, and flushed out all the hard lines on my 67 cougar. Next have to figure out how/where to put the new proportioning valve to reduce pressure to the rear so the discs will work properly, and change out the booster and master cylinder.
Wrench97
Southeastern Pa
Picked the truck up. The excuse is that the bad starter was causing a parasitic draw on the battery pulling it down and keeping the charger from fully charging the battery.
That's a new one on me.....Alternator yea seen a few of them cause a draw, starter not so much unless it's still spinning when you get out of the truck.....
jonshonda
Wisconsin
Been pretty busy despite being fairly sick with covid.
2009 Fit AC compressor failed, so I replaced the; compressor, condenser, and expansion valve. 2 years w/o AC was long enough.
1994 has been up on jack stands for 3 months waiting on custom suspension. It finally came in during my covid down time, and in between feeling like trash I managed to get everything buttoned back up.
Most everything in this world isn't designed for taller folks, and being 6'2" and a big guy I am sick of messing around with things that are just a pain in the *** to use. So I mod'd this US General cart for pressure washing duty. The tires are from the original Simpson cart that came with the pressure washer.
Hooked
League City, Texas
I have this same cart for my meat processing/grinding equipment. I keep it stored in my workshop and after 5-6 years all the paint is falling off in sheets (assuming it's powder coated) and underneath the metal is rusted. My guess is they did a really poor job of prepping the metal prior to the powder coating so at some point I'll be disassembling and repainting it. Pain in the rear.
welder4956
Birmingham, AL USA
Took another shot at installing the undersize boot this morning. After a 15 minute soak in very hot water and a homemade tool fashioned from TIG wire, I was able to stretch the boot over the end of the rack. At least if it ever decides to split on me, I have a NOS replacement on the way.
jonshonda
Wisconsin
If it's a modern PC setup they really shouldn't have to do anything to prep the panels. Most decent PC systems have chemicals in the bath that take care of all the prep prior to the application of the paint.
But for $50 I would likely just buy another cart and set the old one by the curb.
CoogarXR
Continuing the big purge, in preparation for the 80% chance that I might be moving. Even if I don't end up moving, I need to purge anyway, and this is a good motivation.
Taking pictures, listing the "good stuff", starting a donate pile for the "meh" stuff, and scrapping/trashing the rest.
Copymutt
Colorado
Pretty straight forward. A pair of Neodymium magnets epoxied to a 3/4” stick of wood then epoxied to a computer fan. 33k ohm variable resistor & a 5 watt ceramic resistor in series on a heat sink. On/ off switch & a 24v supply. In the bottom of the Erlenmeyer flask is an 1 1/2” oblong steel rod wrapped in shrink tube. The magnets spin the rod & create the vortex. Just a 1/4” plywood box.734D1D24-DDD5-4489-9A7D-32F4E146278A.jpegC489DB52-9B10-4A3D-9036-2D7573B06A90.jpeg286F4BD8-53AA-4959-8617-A354A1FE4851.jpeg89F1BB69-2BA7-47D0-9874-BB9FA10FD6B9.png
