Lock-Tite and anti-seize
bluedog225
Texas
I came across a large box of 1/2” stainless nuts and bolts at restore. Perfect for putting together some solar racking unistrut projects I’m working on.
Unscrewing some of the nuts, I can feel them wanting to seize. Been there and want to avoid. But I also need to lock these in place. I know anti-sieze will work. But it seems like lock-tite would also work. Even though it’s sorta the opposite.
Seems weird to use lock-tite this way so I wanted to check in with you guys.
Thanks
bluedog225
Texas
Thanks. Seems like it would lube it up and provide a buffer. Locknuts or split rings are an option.
Firebrick43
West central Indiana
Loctite is designed to lubricate the threads until it sets up. Second sentence below from a screen shot from Henkels website
It also prevents corrosion as it seals the threads and doesn't let air/water into the threads therefore eliminating corrosion. Once you heat it to 400 degrees it lets go and becomes a powdered lubricant for disassembly
bluedog225
Texas
Great. Thanks!
reader2580
Minneapolis, MN
I installed solar panels on a ground mount rack with stainless fasteners in 2017 or 2018. In 2020 the rack was dismantled and moved to a new location. Most of the stainless fasteners would not come apart so it is good you are trying to avoid the galling.
Old Man Roger
Palm Coast Florida
But will he heat them to 400 degrees?
nadogail
Coronado, CA
IMHO, there are several grades of Stainless, I have found 316 to be the most corrosion resistant, 304 much less corrosion resistant.
316 has not been attracted to my magnets, 304 can be picked up with a strong magnet.
Any fasteners I found at a liquidator or resale shop would automatically be suspected to be counterfeit.
Firebrick43
400 series are magnetic and 300 series is not. 304 CAN become magnetic if cold worked significantly but that is not a universal and if annealed, demagged, or sometimes even a sharp tap after cold working will lose any slight magnetism it may have picked up.
High quality 304 SS fasteners will have it removed after rolling the threads.
Skyman
Central Maryland
Loctite 242 breaks loose easily without the application of heat, but seems to hold well in the absence of extreme vibration. I use it frequently on CRES fasteners. Although I've never conducted any testing that would withstand scientific scrutiny, my experience had led me to conclude that it reduces the well-known galling tendency of CRES threads.
bwringer
Indianapolis
Yes, Loctite will help prevent galling and corrosion. The primary function is locking the threads, yes, but the coating also has important secondary benefits. It also helps sealing.
It doesn't sound like this application would be subject to severe vibration or anything, so you'd be fine with regular old blue stuff. I prefer the chapstick tubes because they're a lot less messy.
WisJim
Menomonie, WI
When I was doing work with small wind turbines, many of them had stainless steel hardware. The manufacturer specified using teflon pipe dope on threads to prevent galling.
