Square taper shank drill bits, what tool to use with?
OccupantRJ
Eastern North Carolina
Here you go. I cut the square shank off and use them in a reversible drill. My dad was a carpenter, so I inherited a few.
Most of those need to be run slower when used in a power drill, don't want to go the full 2500 rpm, will lose the effect of the lead screw.
neophyte
Pennsylvannia
This.
Screw feed drill bits, if even used in power drills, should only be used in very low speed power drills.
The 350RPM slow gear of the milwaukee Hole Hawg right angle drill for example.
Too high of a speed can make the screw feed dangerous.
It should also be pointed out, that many square drive, and Auger buts, are not made out of “heat resistant” steel alloys, and the temper can easily get removed from the cutting points if used in a power drill. (You can tell if you “ruined” a bit, by the bit turning blue from heat).
rlitman
Long Island
I have a bunch of these, and did this with a few when I needed something for a specific task. For the most part, it's not a good idea. The steel isn't up to the high speed cutting of a power drill and will wear down way too fast. And the hand-forged shanks will have lots of runout, so they don't even work well in low-speed high-torque power drills like a Hole Hawg.
I'm all about a good ship auger in my Hole Hawg, but it's going to be a single flute nail-eater that's made for the task.
dscheidt
also, good quality bits in good condition are worth more than a bit to fit a three jaw chuck costs.
