Most of those need to be run slower when used in a power drill, don't want to go the full 2500 rpm, will lose the effect of the lead screw.Here you go. I cut the square shank off and use them in a reversible drill. My dad was a carpenter, so I inherited a few.
This.Most of those need to be run slower when used in a power drill, don't want to go the full 2500 rpm, will lose the effect of the lead screw.
I have a bunch of these, and did this with a few when I needed something for a specific task. For the most part, it's not a good idea. The steel isn't up to the high speed cutting of a power drill and will wear down way too fast. And the hand-forged shanks will have lots of runout, so they don't even work well in low-speed high-torque power drills like a Hole Hawg.Here you go. I cut the square shank off and use them in a reversible drill. My dad was a carpenter, so I inherited a few.
also, good quality bits in good condition are worth more than a bit to fit a three jaw chuck costs.I have a bunch of these, and did this with a few when I needed something for a specific task. For the most part, it's not a good idea. The steel isn't up to the high speed cutting of a power drill and will wear down way too fast. And the hand-forged shanks will have lots of runout, so they don't even work well in low-speed high-torque power drills like a Hole Hawg.
I'm all about a good ship auger in my Hole Hawg, but it's going to be a single flute nail-eater that's made for the task.
