Help wiring a Dayton electric motor
FordMustangKingCobra
Hi, i need a bit of help wiring up an motor electric motor, usually I can do this on my own but this is proving to be a bit of a pain, as this wiring diagram leaves much to be desired in my opinion. Can someone explain to me what the ungrounded side of the line is. And how I would go about hooking up a power switch to this motor.20240802_225040.jpg20240803_000546.jpg20240803_141721.jpg
BillK
Beautiful Southern Maryland
I would think that the "ungrounded" side is the hot side from the breaker (or power cord). Normally the black wire. The "grounded" side would be the neutral or white wire. I have never heard it referred to like that but it makes sense, I guess :)
Normally you would a switch in the black (hot) line feeding it. It looks like you have two power cords ? What is the other one ??
dogdog
I am pretty sure that means HOT... since in the US power grids Neutral is most likely grounded at the main panel.
its pretty straigh forward.
Hot to #1
Neutral to #4
if you wanted reverse rotation interchange red and black from the motor to 2 and 5...
it's 120V only motor.
or try to google translate that to spanish then back to english ?
micromind
Fernley, Nevada, about 30 miles east of Reno.
so you have:
red on 2
black on 5
hot from switch on 1 and
neutral on 4?
If it's connected this way and it doesn't run but only buzzes, most likely the centrifugal start switch is bad (or just needs to be cleaned out/exercised a bit) or the motor is burnt up.
This is a split-phase motor, there is no capacitor.
If you can, turn the shaft as fast as possible while it is energized. If it runs, them the problem is almost certainly the centrifugal start switch.
FrankLee
seMI, 48317
What is the history of the motor? Did it run before?
It can't hurt to open the motor and check things inside. It's not difficult.
FrankLee
seMI, 48317
Is that bearing spring washer in its original position? Usually those are on the fan side of the rotor.
Without installing the end cap on the stator, insert the rotor into the end cap. You may be able to see if the cent switch is closed or still open.
F
Yes that's in its original position, so it looks like the switch is not getting a good contact
F
It looks like in this case it's normally closed
FrankLee
seMI, 48317
That's what I would expect.
Please post another photo like above only zoomed out to show the governor assembly with the disk and weights.
FrankLee
seMI, 48317
Hmmm.
What's going on here with the shiny areas and white spot at the end of the arm? Grease? Glue?
The wire at terminal #1 was repaired. Is that the correct location?
F
Hmmm.
I think that was glue, it was like that when i got it from Granger and that black wire was repaired and it's in the correct location.
FrankLee
seMI, 48317
I'm stumped.
If it will run by manually spinning the rotor, somehow the start windings circuit is either open at power off or the start windings are shot.
Spacing between the cent switch and the governor assembly is critical which is why I was questioning the location of the spring washer.
micromind
Terminal 2 is a teardrop shape with 2 in it and the red wire is attached to it. What is the number in the teardrop under the red? If it's 5, then there are parts missing......like the terminal that sticks through small slot at 5.
Is there a 5 close to the black wire? I don't think the black wire is in the right spot. Could easily be wrong though.
F
The black and the red are interchangeable, reversing them just changes the direction of the motor
