I use and like BIRCHWOOD metal bluing. I wipe a thin layer of ATF on the surface of the treated metal and the problem of rusting is over.This really would refer to a lot of tools but how do you keep rust off the table and column of your drill press? Have not lived in a humid environment in 40 years
Thanks
Yep!I use and like BIRCHWOOD metal bluing. I wipe a thin layer of ATF on the surface of the treated metal and the problem of rusting is over.
Wipe down with a mixture of atf/gear oil. Use new gear oil left in a jug to avoid the nasty smelling stuff....unless you like it..This really would refer to a lot of tools but how do you keep rust off the table and column of your drill press? Have not lived in a humid environment in 40 years
Thanks
My brother and I share a building and he had been encouraging me to buy a de-humidifier. Once I did the rust on tools and equipment went to zero. I am surprised by how much water is drawn out of the air on my side of the building.Buy a dehumidifier....and oil.
DEhumidifier! They do work and it is amazing how much moisture can be in a building, especially a new building with new concrete floors.My brother and I share a building and he had been encouraging me to buy a humidifier. Once I did the rust on tools and equipment went to zero. I am surprised by how much water is drawn out of the air on my side of the building.
When I brought my old 3-phase drill press home years ago I broke it down, cleaned it up, and gave everything a light coat of motor oil. An old quart that was laying around. I buffed the excess away.This really would refer to a lot of tools but how do you keep rust off the table and column of your drill press? Have not lived in a humid environment in 40 years
Thanks
This only works if your ambient air temperature is 50-55 degrees F or higher. My dehumidifier doesn't even turn on the compressor if it's under 55 deg. F (prevents it from freezing up). In my unheated garage where I live, this won't do me much good for 6-8 months of the year. My nice drill press (20" Craftsman from the 1980s) has a light coating of rust on it now. It still drills holes when I need it to. As one ages, one realizes that some things, no matter how annoying, aren't a very high priority. My kids and wife certainly don't care if my drill press table is shiny or rusty.Buy a dehumidifier....and oil.
Well yes. But if it's under 50-55, there's a lot less moisture in the air because the dew point can't exceed the ambient temperature. It's not just that the dehumidifier doesn't want to freeze up, it's that below 50F or so you don't need it.This only works if your ambient air temperature is 50-55 degrees F or higher. My dehumidifier doesn't even turn on the compressor if it's under 55 deg. F (prevents it from freezing up). In my unheated garage where I live, this won't do me much good for 6-8 months of the year. My nice drill press (20" Craftsman from the 1980s) has a light coating of rust on it now. It still drills holes when I need it to. As one ages, one realizes that some things, no matter how annoying, aren't a very high priority. My kids and wife certainly don't care if my drill press table is shiny or rusty.
Wouldn't it be kind of messy to clean off, when using the table?Fluid Film, available at most parts stores.
You are absolutely correct. LoLDEhumidifier! They do work and it is amazing how much moisture can be in a building, especially a new building with new concrete floors.
I certainly agree 100%Fluid Film, available at most parts stores.
Ridiculous is an understatement. WTF?Johnsons paste wax but holy **** apparently discontinued and it's selling for ridiculous prices.
What makes it ridiculous is there there are MANY excellent substitute products. Look for bowling alley paste wax. Lundmark's is what I used to use.
^^ This. It doesn't have to be Johnson's brand.What makes it ridiculous is there there are MANY excellent substitute products. Look for bowling alley paste wax. Lundmark's is what I used to use.
I've moved over the Renaissance wax for everything now.
Wow, this may replace "retirement lights", or Bitcoin, as the next big thing. I kinda regret giving a friend a brand new can now
