Air tool oil
kmorgancraw
So I've always used Snap on oil for all my air tools but my Snap On guy is MIA most weeks. Is there anything magic about Snap On oil or will others do just fine? What are some other time tested alternatives?
wellstig1
Torrance, Ca
Any air tool oil is fine, at least your oiling your tools. 90% of guys I've worked with never oil any of their air tools. I do prefer this lucas stuff, mainly because I get it for free though.
jteck75
Benton Ky.
Most air tool oil (as in all oil) is produced by the same handful of companies. I usually buy the big bottle of air tool oil at Napa,and I have never had any lubrication related air tool faliures. I've even bought the Harbor Freight oil,it's one of the few USA made products I've ever found in there.
G1GRANDEUR
I heard this, marvel mystery air oil can mess up the seals inside air gun and ruins it.
I'd use SO oil, just to be safe and feel better :p
ozzy214
https://t.me/pump_upp
I just use good ole fashioned trans fluid. Save some from a ****** job at work and oil them up twice a week
My snap on far air rachet is stil;l going strong after 10 years due to this.
mrshaun
Killeen - Fort Hood
exxon/mobil is listed under the msds sheet for the snap on air tool oil
Someone from snapon power tools said that a certain version of the Marvel oil had been eating up the seals in a few tools.
Fedwrench
Valley of the sun
Lucas makes some good air tool oil. The Blaster folks also make air tool conditioner which I like. I never had a problem with any brand of air tool oil too include the Marvel stuff.
lipadj46
Is the MMO original oil ruining the seals or their air tool oil formula?
Their Air Tool Oil Link:
http://www.marvelmysteryoil.com/index.php/site/mat/
I just picked up a small bottle of it, I'll switch if this is the oil that is causing problems.
MMO has been around for many many decades, I doubt either one damages seals. Not really much in it, pale oil, naptha and a few other odds and ends. Nothing that stands out as a seal sweller/killer.
mrshaun
Killeen - Fort Hood
when snap on tore the tool down the seals were impregnated and they contained marvel mystery oil. they have a lab that they send some of the parts to ( snap on lab ) and they said each one that was messed up contained a special version or marvel mystery oil. I havent seen the oil, but it was only out for a limited time....
barney rubble
I've been using regular MMO, untill we started selling the air tool oil a few years ago, for close to 40 years and never had any problems.
Other than not remembering to use it often enough.
mrshaun
Killeen - Fort Hood
that is a big part of air tool failure. running water through them and not oiling them after you use it, then it sits in your box over the weekend and in texas its hot cold hot cold and boom you have a little rust form on the inside and its down hill from there.
Fudge
NorCal
I use Senco air tool oil. Started buying it for my nail gun when I was framing houses. I bought a big bottle and haven't run out yet. It seems to work just fine. Before that I used some industrial stuff my dad would get a work, but now that he retired that source dried up.
Moose-LandTran
The Brink of Insanity (England)
I use Bostitch air tool oil. I opened a catalogue, and there it was. So i bought that one. No complaints so far, everything still works fine as it should. I use Castrol LM (Lithium-based) grease in the impact guns' hammer cases.
a.pengue
Just wondering, since im getting an aircat soon with the twin clutch and it says this on their website:
_________________
Twin Hammer- Use Lithium or bearing grease. One pump every few weeks is all you need.
Twin Clutch- Use 1 oz. of 30w motor oil, but only if you see it leaking. Otherwise, the
tool should be fine. For routine maintenance, just oil through the air inlet every night and
leave the handle pointing up. It will be ready to go the next morning. DO NOT USE
MARVEL AIR TOOL OIL. Light weight air tool oil is all you need.
__________________
lightweight? as in just regular air tool oil? :confused:
rayzor32
Buffalo, NY
I used to use the PB blaster air tool conditioner, this stuff works fantastic if you have lots of water in your lines or you need to revive an old tool thats been neglected it will bring it back to life and clean it out. The last shop I worked in was terrible, my impact gun might as well been a squirt gun and of course no regulators on the compressor either so water+175psi= oiling 3+ times a day with PB.
I been using amflo air tool oil I found cheap at HF surprising its made in the usa, it works good. The snap on oil is good too but im too cheap. Back in my tire shop days we used MMO no problems and some other stuff called arctic freeze, the MMO was better, I knew an old timer that was all he used.
I always oil at the end of the day.
wreckercologist
cyber-tool hell
i end up using hyd oil in mine.
when i used to take care of my impacts and grinders i always used SO oil.
:beer:
I little different additive package, but about the same as auto trans fluid.
I used Marvel for over a decade. After I ran out I switched over to Snap-on air tool oil for no other reason than it was quick and easy. I didn't even get an 1/8 through the bottle and the boss handed me a bottle of Lucas air tool oil. It's probably all in my head, but the Lucas seemed to help out a few of my tools...........plus it was free.:pimpflash
