Steel_Rain
- Joined
- Apr 23, 2024
- Messages
- 1,419
What do you mean you have both? The green are the drivers. I think Yellow are Torx. White are Phillips and Slotted....
I don't have both, only the Vectors, but they look nearly identical except for the handles. Your's is the nicer set.
I’ve had trouble locating a set of these. I guess my google foo skills are not to good. Mind sharing where you found the set? Thanks.
I’ve never bought a set of these, just individual drivers, but the prices were generally very fair. I had a look in the catalogue and see no sets of these listed, but they don’t list any of the other sets either.I’ve had trouble locating a set of these. I guess my google foo skills are not to good. Mind sharing where you found the set? Thanks.
Yes, there’s not a lot to dislike.Great info on these. I like the tang though, hex top shank and size range of 75mm-200mm.
Hmmmmmmm
Only seen sets of those from a few sellers on ebayI’ve had trouble locating a set of these. I guess my google foo skills are not to good. Mind sharing where you found the set? Thanks.
I just checked this set on amazon says they fit both JIS & Phillips. First time I have seen that. JIS and Phillips are close but there are subtle differences between the 2 standards.Has the feel of PB swiss in the handles and I must say these are close to a "perfect grip".
I’ve used JIS/DIN on Phillips for years. If anything, JIS/DIN fits better.
I really like the Kuru Toga pencils.I took a closer look at the retail package for the "standard" pencils and it says Made in China, which surprises me. The "pipe slide" pencil is made in Japan. There was no COO information on the package of the "Roulette" pencil.
Beautiful impact wrench! Would love to try that one.
I have the "premium" model and it's definitely made in japan (it is moulded into the plastic).I really like the Kuru Toga pencils.
I ended up with a small selection, for different lead grades.
When I bought mine, which was some years back, they were definitely made in Japan, I remember checking the packing. The plastic is definitely Japanese, as is the overall build quality.
I’m sorry they have decided to outsource these. The Japanese made ones were not prohibitively expensive, but these are the sort of things that do need to be made exactly right to function properly.
There are a lot of different models. Probably not a complete list:I have the "premium" model and it's definitely made in japan (it is moulded into the plastic).
I have the Vessel HRH2W 1/4” kit from Vessel. Per CP the tool addict, the ratchet is head/shank is made in Taiwan along with the sockets, but the “compo” handle is made in Japan:There are a lot of different models. Probably not a complete list:
Standard
Rubber Grip
High Grade
Roulette
Alpha Gel
Alpha Gel Switch
KS
Metal
Dive
Pipe Slide
Advance
Advance Upgrade
I recently bought a metal version, and it says made in Japan. Maybe the writing is on the wall...
It's weird to me, because I bought a "starter set" with the standard version, some extra erasers and a container of leads for... $6 from Walmart? That was several years ago, but still... It doesn't really seem like they needed to bring the price down.
In other news, Vessel sells ratchets? They have the wooden handle like some of their screwdrivers. Might be a little too bulky. I was looking at model hrh2w, which Zoro says is made in Taiwan. Has anyone used one?
You just cost me another hundred, Ordered a set from Ebay.
Mind linking the seller?You just cost me another hundred, Ordered a set from Ebay.
I resisted and only purchased the one shown. I must admit it is beautiful and I could only find a set sold on eBay. Vessel also makes a blue handle one just as beautiful.You just cost me another hundred, Ordered a set from Ebay.
Yeah, but you know... that P2 tends to cam out sometimes, and remember when you bent that flat head a little? And I know that buggered handle irritates your hand when you really get after it...I keep resisting this set reminding myself how many sets of screwdrivers I have...
A quality one would use a metal burr. At least that's how it is with coffee grinders. The ceramic ones are not quality.Later I purchased a Kyocera ceramic pepper mill, which worked fine until it unexpectedly broke today.
Never been happy with the one I have. I just ordered a 12-in mill, I just didn't know which brand I wantedA quality one would use a metal burr. At least that's how it is with coffee grinders. The ceramic ones are not quality.
The French-made Peugeot pepper and salt grinder is the most iconic design and certainly one of the most reliable grinders on the market. I would not recommend anything else. They had the patent on their burr design and it is still made the exact same way as it always was since 1874.
So.... are you tellin' me I should trade in my old beat up Italian job?The French-made Peugeot pepper and salt grinder
That one is already on the way. Kyocera is known for their advanced ceramics, and the mill I bought from them was supposed to be a high end one.A quality one would use a metal burr. At least that's how it is with coffee grinders. The ceramic ones are not quality.
