Tools of Japan
Steel_Rain
Right! I have a set of those green Vectors sitting in my Amazon Japan cart, but haven't pulled the trigger.
I'm wondering how they compare to the Vessel's I've already have:
Do you have both?
Ohio Andy
Columbus, Ohio
Do you have both?
What do you mean you have both? The green are the drivers. I think Yellow are Torx. White are Phillips and Slotted....
Or do you mean the Tang-Thru versions that have a metal (except on the stubbies)...
Or do you mean the Megadora versions?
Inquiring minds want to know.... and I am also curious! :cool:
Dave455
Sussex, England
I’ve had trouble locating a set of these. I guess my google foo skills are not to good. Mind sharing where you found the set? Thanks.
I’ve never bought a set of these, just individual drivers, but the prices were generally very fair. I had a look in the catalogue and see no sets of these listed, but they don’t list any of the other sets either.
I’ve bought Vessel from various sources over the years, including a local electrical factor and Amazon.
Cheapest option at the moment seems to be buying direct from Japan, either Amazon.jp or one of the big online suppliers such as Webike.
The Powegrip seem to be Vessels premium range. The hard cellulose acetate (not CAB, so they don’t smell) handles are incredibly durable, as is the chrome plating on the blades. They are certainly my favourites.
Part numbers are below. The different types of drivers have different coloured handles, which is a feature I like.
Steel_Rain
Great info on these. I like the tang though, hex top shank and size range of 75mm-200mm.
Hmmmmmmm
Dave455
Sussex, England
Hmmmmmmm
Yes, there’s not a lot to dislike.
I don’t always like through tang drivers. I’ve tried a few that feel very unbalanced, but these feel really nice. I think the forged hex at the top of the blade helps correct the balance, but they are obviously very well thought through.
The sizes equate to a fairly standard 3, 4, 6 and 8 inch which I suspect we all feel comfortable with.
I have the regular, Phillips and Torx (and the bit driver). I have yet to track down a set of the ball hex, but will probably order from Japan at some point.
F-22
I have a few various Vessel drivers and the powrgrip is definitely my favourite. Followed closely by their 230W bit driver (very sturdy design). And the Crystaline screwdrivers if the powergrip are a bit too heavy duty in some cases.
ronkz650
Denver, CO
Some Phillips screws JIS just don't fit. I have a wiha long phillips screwdriver. It is by far the worst fit in a JIS screw in the history of screwdrivers, but on a pinball machine it fits the Phillips screws perfectly where the Vessel JIS fits terrible. Most screws either can probably be used without much notice, but there are definitely places a JIS screwdriver just doesn't fit.
Steel_Rain
Makita GWT01 (XGT 3/4" drive):
Koken 16644AL 3/4" to 1/2" adaptor:
You really see how big the jump is from 1/2" to 3/4" when you compare the two:
The Japanese really do make quality, heavy industrial equipment, even in this class of non-air tools.
Outahere
Idaho
Some Mitsubishi/UNI Kuru Toga mechanical pencils (0.5mm lead) purchased from Amazon-US.
From L to R:
"Roulette"
"Pipe slide"
"Standard"
"Standard"
I took a closer look at the retail package for the "standard" pencils and it says Made in China, which surprises me. The "pipe slide" pencil is made in Japan. There was no COO information on the package of the "Roulette" pencil.
Dave455
Sussex, England
I really like the Kuru Toga pencils.
I ended up with a small selection, for different lead grades.
When I bought mine, which was some years back, they were definitely made in Japan, I remember checking the packing. The plastic is definitely Japanese, as is the overall build quality.
I’m sorry they have decided to outsource these. The Japanese made ones were not prohibitively expensive, but these are the sort of things that do need to be made exactly right to function properly.
KnurledNut
n/a
Beautiful impact wrench! Would love to try that one.
My made-in-Japan XWT07 3/4” has took a lickin' and keeps on tickin'. Still no slouch, but that 40v stuff looks great! 💪
F-22
I have the "premium" model and it's definitely made in japan (it is moulded into the plastic).
terrific
There are a lot of different models. Probably not a complete list:
Standard
Rubber Grip
High Grade
Roulette
Alpha Gel
Alpha Gel Switch
KS
Metal
Dive
Pipe Slide
Advance
Advance Upgrade
I recently bought a metal version, and it says made in Japan. Maybe the writing is on the wall...
It's weird to me, because I bought a "starter set" with the standard version, some extra erasers and a container of leads for... $6 from Walmart? That was several years ago, but still... It doesn't really seem like they needed to bring the price down.
In other news, Vessel sells ratchets? They have the wooden handle like some of their screwdrivers. Might be a little too bulky. I was looking at model hrh2w, which Zoro says is made in Taiwan. Has anyone used one?
Steel_Rain
Standard
Rubber Grip
High Grade
Roulette
Alpha Gel
Alpha Gel Switch
KS
Metal
Dive
Pipe Slide
Advance
Advance Upgrade
I have the Vessel HRH2W 1/4” kit from Vessel. Per CP the tool addict, the ratchet is head/shank is made in Taiwan along with the sockets, but the “compo” handle is made in Japan:
It’s a decent set, but not my first 1/4” set I would run out to buy. The metal has a matte chrome pepper finish.
Here is the rachet and stubby 1/4” driver:
Steel_Rain
It’s honestly overkill for a 1/4” drive. But it feels quality. It would be great to have a slim line version of this on a 1/2” long handle ratchet.
16again
Boynton Beach, FL.
Reed Prince
Northern Virginia USA
A few years ago I bought a Kyocera ceramic kitchen knife, and it is one of my favorite kitchen tools.
It has a different blade angle than steel knives, so I bought the home sharpener. The AA alkaline batteries the unit was designed for couldn't provide enough current to keep the wheel from bogging down, so I hooked up a couple of 18650s and now it runs like a champ.
Later I purchased a Kyocera ceramic pepper mill, which worked fine until it unexpectedly broke today.
So this is one Japanese kitchen tool that I cannot recommend.
F-22
A quality one would use a metal burr. At least that's how it is with coffee grinders. The ceramic ones are not quality.
The French-made Peugeot pepper and salt grinder is the most iconic design and certainly one of the most reliable grinders on the market. I would not recommend anything else. They had the patent on their burr design and it is still made the exact same way as it always was since 1874.
Ohio Andy
Columbus, Ohio
Never been happy with the one I have. I just ordered a 12-in mill, I just didn't know which brand I wanted
Reed Prince
That one is already on the way. Kyocera is known for their advanced ceramics, and the mill I bought from them was supposed to be a high end one.
