The Electric Blue Garage
Squirlz
The Electric Blue Garage is Back! Update page 4.
Work began in earnest on our 28' x 40' garage on Labor Day. Here is the space before. The crab apple tree that's behind the MINI on the left (hers) has to go.
Tree gone and walls are strung out.
Post holes dug, lumber delivered.
Sticks in the ground!
A little rough leveling.
Where we stand today.
Next step is to bring in the water and sewerage and electricity, floor drain and pour the concrete! This garage will be bigger than our house. Plans include a portable 4-post Titan lift, a half bath, fridge, bar and big-screen TV.
Walls will be 11' with scissor trusses. Probably go with fluorescents in the ceiling. This is my first (and probably last) garage build so I want to do everything right. I've learned a lot from you guys and now is the time to pile on your ideas if you can help me out.
Here is an artist's rendition of the finished product.
More to come as work progresses!
naki kid
New Plmouth_New Zealand
You even got mini's over there. some one was going through New Zealand a few years back and bying as many as they could and were shiping them to japan and L.A.Don't no if they are still doing that.
You will be able to get a lot of mini's in that garage.good luck on the build.Ray.
Squirlz
The trusses arrived today.
They somehow dropped these in the front yard this morning without waking us up!
No work has been done since last Thursday. Waiting for clearance to hook into the water system. That will happen tomorrow and things will move quickly from there on out.
Squirlz
Well there were some questions by the Township and a Stop Work Order was issued Tuesday. Turns out the back wall has to be 8 feet from the property line, not 5 like they approved before. The poor builder has to eat it all.
They will get going again tomorrow.
duallypilot
Raytown, MO
so is everything moving forward or are you going to shorten the garage? I love it when the guys in the office say one thing and the field inspectors say another.
I too like the artist rendering.. Looks like when I play in photoshop!!!
Squirlz
They're going to move the whole thing forward. It's almost like starting over.
Squirlz
I guess not. I'm sure the contractor did all he could do as he has to eat the cost.
aqr81
Central Valley, Ca.
Sorry to hear this came up for you. You will have a bit of a delay but at least it's all going to work out for you. I have been going through a similar series of issues and red tape with my project. Hang in there, it will all work out. Look forward to your updates.
Squirlz
Trenching out for water and sewer. The backhoe barely fit in the shallow backyard.
They left for the day, and they left the keys!
Anyone need some excavatin'?
intimadatorsquizz
Telford,PA
that ***** about having to move it, but at least you don't have to front the bill...
you have that look of a kid in a candy store holding those keys...
Squirlz
Concrete was poured yesterday and they've been framing all day.
Squirlz
Lots more got done today, but one problem. After they left I discovered they made the walls 10' high, not 11" as specified. I intend to have a portable 4 post lift soon. With scissor trusses can I be happy with 10" and several thousand dollars they'd better give me back? If 10' isn't enough for a lift the walls might as well be 8'. I'm not happy.
JDMopar
Asheville,NC
If you payed for 11' , I'd make em raise it up. My ceiling is 11' without scissor trusses, and it is adequate for the Challengers,Cudas and Roadrunner. If it was a foot higher, I wouldn't worry when I have something way up on my 4 post lift. Now is the time to fix it, so you're not unhappy with it forever. Good luck.:thumbup:
ct71rr
Massachusetts
Nice progress. That place is huge!! I would also have them fix the height issue now. Or, have the mistake reflected in the bill.
larry_g
oregon
I would get the builder out asap with the drawings in hand and confirm what is going on re the height problem. Was the 11 a verble item or does it show on the prints as a clear 11' at the point your measuring. To some eve height is a nominal thing, and it can be from grade and not finished floor.
lg
no neat sig line
Squirlz
Turns out they simply couldn't make the walls any higher and meet code. Not sure why he didn't tell me, but we'll deal with it. Any way, the shingles arrived and more sheathing has been done. It rained on the exposed sheathing all day today. Is that a problem?
Squirlz
Got A LOT done in the last 2 days. These pictures are all from today.
Had builders doing the walls, roofers laying down shingles, and concrete crew prepping the driveway.
Busting up the old driveway.
Here's where we are at the end of the day.
Tomorrow a sea of concrete gets poured. I'll update you all then!
Nuts
Baker City, Or
""Turns out they simply couldn't make the walls any higher and meet code. Not sure why he didn't tell me, but we'll deal with it.""
Euphemism for, "We fucked up again, and hope you don't check the zoning rules, and make me build this whole shop again."
Nice shop anyway, a regular Mini Castle.
Nuts
Squirlz
We're in Michigan and they sank them well below the frost line; 5 feet or so.
NUTTSGT
Northern Central Ohio
It's looking good. I'd guess the rain is holding off your concrete too. Are they framing the inside in between the posts for 16"o.c. to insulate and finish ?
egads74
Where is all the water going that comes off the roof? The area in front of the garage doors appears to tilt to the front corner with no escape. Road appears higher... out your front door and to the left the road appears lower? Any way to drain and gravity feed to that area? Or do you own a boat? now is the time...
Squirlz
NUTTSGT: Yes, they finished studding today and it will be insulated and walled with 1/2" sanded plywood.
70CHEVY: We are in Okemos
egads74: There will be gutters directing the water away.
They started work on the driveway before 8 this morning and are just now finishing at 7:45.. It's looking GREAT.
We wanted the driveway to be nice but it's going to be so huge. My wife Molly wanted curves and had an idea for a special touch on the borders.
Two colors of powder will be used to create a decorative "brick" border to help accentuate the curves.
First the guy scribes out the 12" border.
Then the powders are carefully applied.
Then the "bricks" are scored and a texture is pressed on.
The color will be different when they wash off the powders and seal the border. I can't wait to see the finished product.
