nail puller for larger nails
BTL-A4
Santa Clarita
I got the pneumatic denailer and it worked really well. Wear safety glasses and keep everyone out of the way because a few of the nails ricochet off the bottom of the trash can into the garage.
I used the sliding nail puller to get the nails with broken heads out; worked really well. I used a steady, firm pull to get most of them out. It's long enough that it has enough leverage. Some of the nails were 4" long, but it got them out just fine.
toplessHO
central florida
I need something that digs in and grips the heads of nails that have been sheared off flush. I used a chisel to dig around the head, then bigger wire cutters to pull the shaft up and out. That works on the smaller nails best. I'll have to take a look at a tool like the one referenced above (thanks, @Dig Doug ) and see if it looks like it will dig into the wood a bit. I have 100's of nails to remove. I can do a few at a time, though.
I bought some of these
good tool to have
theoldwizard1
SE MI
First, it you want a nail that won't come out, hot dipped galvanized, ardox, twist !
I had a quantity that had to be removed. I used a FULL SIZED CROWBAR ! Sometimes the head would rip off. Vice Grips ! A small block of wood under the crowbar would add leverage.
BTL-A4
Santa Clarita
I had quite a few nails heads come off. The claw hammer took care of most of them. Anything that didn't get, the slider got.
