Its helping me justify keeping the Hackzall around. Basically I am looking to retire the Hackzall to cutting up trash to fit in the bin (including folding chairs).What the hell do you use the folding chair for? I'm am SO confused....
Not 6.0. He's saying the 5.0 HO is the only battery that delivers those specs.Looks like a pretty big leap in improvement for the new stubby @ 400 lbs vs 250 lbs for the gen 1. Not exactly double but a pretty decent improvement. 3 LED lights is also a big feature for me.
I think Milwaukee ff'ed up with the double trigger tap torque setting adjustment. I personally leave my tools on one setting and feather the trigger if I want less torque. Only time I adjust the settings is when working with a less experienced user. Is this going to be one of those deal breakers?
Edit: also sounds like HO 6.0 batteries are almost a requirement
Thanks for the correction.Not 6.0. He's saying the 5.0 HO is the only battery that delivers those specs.
And yeah, the interface change is a huge bummer for me. Even the trend toward the little clicky electronic buttons vs actual mechanical switches kind of bugs me, but I get that they have to do something to shrink the size of the tool. Making a 1 button interface using the trigger though? I can only imagine that will lead to trouble.
Looks like you put your tools to good use. Electrician? User name checks outI'm not going to list everything, but this is what I have on just my service truck. Almost everything on it is duplicated at the shop and then some. If I don't have it, I probably don't need it. That doesn't mean I don't want it though
I am personally going to have a hard time as I think I have trained my trigger finger for a little double tap action. Hopefully it only switches modes on a full trigger depression. This being said, my kids play with my impacts all of the time so I could see the modes being all out of whack. At least it doesn't require a bluetooth phone connection to change any of the settings yet.
They are well used, some would even say abused. I do have the old style M18 vacuum as well as the M18 Hole Hawg and Super Hawg, but they are buried on the shelf and might nit be visible in the photo.Looks like you put your tools to good use. Electrician? User name checks out
Vacuum and hole hawg I thought was pretty common among electricians.
good to know. That doesn't seem so bad as I don't leave it in neutral. I think I still prefer the button on the top that the Gen 1 had though.The only saving grace on the trigger thing is that it only changes modes while in “neutral”, ie when the direction switch is in between forward and reverse. If it was always active that would be an absolute deal breaker for me.
I had a really good run with my 6.0's, not experiencing any of the common issues until just last week I had one give me the flashing red/green lights on the charger. I was able to jump start it but it made me think the end might be nigh.Agreed, the trigger tap to change modes may be bad. Or could be good. I'm just worried I'll hate it when accidentally pressing the F/R switch by mistake, which I do on occasion.
Fortunately I'm down to mostly 5.0 ho m12 batteries except for 2 cp ones.
I haven't tried it yet, but I think I like the idea. This new way, you can change the mode with one hand. So if you're holding a bolt or nut with your left hand and realize you're in the wrong mode, you can switch it to neutral, change the mode, then switch back to forward/reverse. With the old way, you would have to set the nut/bolt down, press the button with your left hand until the correct mode was active, then pick the nut/bolt back up. In the end, it might be too weird to get used to, but I'm glad they're trying something new.good to know. That doesn't seem so bad as I don't leave it in neutral. I think I still prefer the button on the top that the Gen 1 had though.
According to torque test channel they aren’t courageous or brave to try this new method they are doing it because it’s the only way to fit the bigger motor in the same size case because there’s no room for a selector switch anymore with the bigger motorI haven't tried it yet, but I think I like the idea. This new way, you can change the mode with one hand. So if you're holding a bolt or nut with your left hand and realize you're in the wrong mode, you can switch it to neutral, change the mode, then switch back to forward/reverse. With the old way, you would have to set the nut/bolt down, press the button with your left hand until the correct mode was active, then pick the nut/bolt back up. In the end, it might be too weird to get used to, but I'm glad they're trying something new.
This weekend saw the Ego 16" chainsaw and pole saw, and I've been doing a bunch of cleanup with the M12 Hatchet instead of the Hackzall - I just don't like it for limbing/cleanup.GJ got me on Hackzall originally too, but the little branches are its kryptonite. Usually after 10 seconds of watching the little branches flop around I walk in shame back to my shed for a pair of loppers.
All is not lost of the Hackzall. A torch blade will probably live on that thing. We just retired our 3rd folding chair this month. Its great at helping stuff fit in the trash can.
The Gen2 Mid is nearly as small as the Stubby, and has more grump, but if you're only on M12 I'd go with the new Stubby (and a new 5.0 battery)I'm really on the fence about opting for the new M12 1/2", or just going for the M18.
Only problem is I'd have to buy a kit because I don't have anything M18 these days and I don't really want or need anything else M18 (beyond a 1/2" impact).
I love the idea of being able to switch modes one-handed. The question is will I do it by accident...Agreed, the trigger tap to change modes may be bad. Or could be good. I'm just worried I'll hate it when accidentally pressing the F/R switch by mistake, which I do on occasion.
the prob is accidentally changing the setting even if you just are happy keeping it on the same one all the time. I haven’t held one yet but the reviewers said they accidentally changed the mode while trying to use the triggerAs a user who rarely changes modes the lack of dedicated mode selector switch seems less of a big deal. I tend not to leave my impact tools in neutral as well.
Not sure why they are trying to sell this as an ergonomic improvement though. They should just be honest that it was packaging constraint.
In tricky situations you almost have to be lucky to have the indicator pointed at you to make sure you switched to the right mode, I would think.
What was the fix? Replace an o-ring or something?
I find all of those things jumpy on really small stuff, and the Hatchet is a lot faster for branches/etc.You don't like the Hackzall for cleanup? What don't you like about it?
I've found that chains jump off the bar when you get too close to really small stuff, so I'd think the Hackzall would be better there?
Mike
I have that M12 hedge trimmer as well. I need to use my corded Stihl trimmer in the spring/early summer when I let the shrubs get too overgrown. The M12 works great for keeping them in check the rest of the season.I have one of these and it works ok on smaller stuff. Good for detail work but even 1/2" thick stuff it really struggles. I've been wanting to pick up a m18 hatchet myself. I have a big ash tree in the front yard I need to cut back. The small 1 handed hedge trimmer is too small to do it, the big one is too unwieldy, as is my larger chainsaw. I could use the hackzall but somehow the hatchet seems like it would work better for this in my head.
I had no idea that existed.
Not dumb at all, but they make you pay $130 for a slow version:I've always been puzzled that cars run on 12v systems yet we always use inverters to get back to 120v and then our chargers charge batteries at 12-18v. Would it be dumb for Milwaukee to make a charger that runs off 12v?
UPDATE: Arriving MondayI guess I'll find out soon... (mine is hopefully shipping this week)
