Saylor-Beall...Original or Clone...Here is the answer...
The Tool Tyrant
Bonita, Ca. (San Diego)
This question has been mentioned a few times on GJ. Many folks assume that if 'MADE IN USA' is not cast on the case, that's it's a clone. I have 2 older SB pumps, and neither have it, but do have the SB serial # tag.
I sent an e-mail to Saylor-Beall asking the question and stating that I assumed they started including the 'MADE IN USA' when the clones started appearing.
The following is the response I received...
You are correct in this reasoning. I asked around our factory and while I couldn't come up with an exact date, it appears we started doing it some time in the mid 80's in response to our compressor getting cloned. It's important to check the pump itself, however, because many pumps have been switched out over the years, so an original saylor-beall tank could have a newer clone compressor pump on top. There are two other easy tells for our clones (besides serial numbers). First is we believe we have always cast part numbers directly into our parts. Our part numbers are 4 digit numbers, so you should be able to find a casting somewhere on the pump with the part number. Second, all of our pump's screws and bolts are in the imperial system, while all of the clones are in the metric system.
Hope that helps!
Andrew McFee
Marketing Director
Saylor-Beall Manufacturing
winnievan
OR
Bringing this back from the dead… just got an older Saylor Beall for $150!!
Runs and works great — so even if it’s a clone (I don’t think it is) I think I made out ok :)
winnievan
OR
With my Preggers wife at the hospital currently but here’s the only photo I have — a preview of the very lame Facebook ad that simply said “air compressor”IMG_2897.pngIMG_2898.jpeg
Jswain
Calgary, AB
With his prego wife @ the hospital posting on GJ bout buying a $150 Saylor beall...you sir, are a legend!
winnievan
OR
it was only Braxton-Hicks… I’ll add more photos of that unit when I get to the shop… our boy is 5 months old now tho!!
now that we have two kids, I always thought I should have two Saylor-Beall compressors too— that way they won’t have to fight over it when I die (I’m under 40) and it’s still running strong!!
So… I found another “80 Gallon Air Compressor” on Facebook… got it home last night it’s still sitting in the trailer. I had to pay double what I paid for the first one — a blood curdling $300 Ameribucks.
It’s a 705 pump on an 80 gallon tank — not sure on HP of motor haven’t scraped the dust off the nameplate yet.
Guy got it doing a commercial clean out of an auto parts store in Eugene, OR — said he had it sitting for years at his place — and just wanted to get it gone. He took it apart to get it in his truck—and never put it back together!! Made for a very easy load out with just a hand truck and ramps onto the trailer.
As for the first one — it turned out to be a 703 Pump with a 2HP motor and a 60 gallon tank—“small” for the Saylor-Beall world with only 7.5CFM @ 175PSI!!
The unloader was stuck and was leaking air past the compression fitting — about 2 bucks in parts and it was fixed. It’s in use at our shop and kicking ****! It’s a great compressor. It’s missing a fan shroud but OSHA doesn’t visit me so it’s ok!
I’ll do a photo bomb of both of these when I get a moment!
winnievan
OR
here’s some pics — does anyone know what this thing is:
winnievan
OR
Thanks — that definitely makes sense!
Weirdly enough — the motor/pump config on this compressor
is opposite my other Saylor Beall.
Kinda strange!!
ford freak
Orange county ca
Did you buy that 703 pump?
I'm in need of a crankshaft for my 705. Ended up buying a bad compressor, got screwed and need to replace crank.
