Double bubble flare- update
trashyman
Not sure if a double bubble flare is even a thing but that's what it appears like to me. It's on my Jenn-Air gas range. Part number WP74010206 for it is obsolete. A single bubble wont work as the jamb nut threads bottom out before it tightens the line. I have a mastercool flaring tool but this one is kicking my ****. I considered chucking the nut in the lathe and taking off the first two or three threads but I am not sure that will work either. The hex head will probably bottom out then. Am I missing something simple?
DGersic
DeKalb, IL
Simple? No. Looks like a bubble flare, but with extra depth. Maybe that’s important for guaranteeing that the fitting is gas tight. Can you change / convert whatever this fits in to to some standard fitting?
T
trashyman
Great idea but unfortunately I can't. One end goes directly into the regulator.
dogdog
There was this thread here that some one made a mini tubing roller from a then $5 HF tubing cutter. Those bubbles are probably rolled, not compress bubbles.
gregs
The short piece you have, does it stick out past the nut when installed? If it does, can you find a compression coupler that would fit it and patch the line together? Maybe find another similiar line to do it with? Guessing you already searched ebay? Sometimes you can find a dismantler that has other parts listed for the same model and contact them to see if they have other parts.
DGersic
DeKalb, IL
T
trashyman
I checked ebay. You're right, a lot of times you can find what you're looking for. No go on the coupler the line broke right at the manifold from me lifting up the top too many times. 🫤
vhol5
West Texas
Would a standard male flare fitting fit into that regulator? If so, maybe a male/male fitting then a single flare with a nut on that?
T
trashyman
Next question is would it seal up without the bubble flare underneath or would pipe dope on threads be fine? I will of course spray soapy water on the fittings to double check in the end
Imatk
Hell I've never even been able to make a SINGLE bubble flare so two of them... nope.
T
trashyman
The range lives. Some may not like my "fix" but it saved me several thousand dollars and it don't leak. I ended up buying a PC of 3/8 ID alum tube to fit over the 3/8 OD tube and sawed off just under an 1/8" long piece. That piece essentially took the place of the second bubble and acted as a spacer. I ran it across a file to flatten it up and take out any inconsistencies then installed it after the jam nut and before I flared the end. Thanks all for the advise.(y)
