MushCreek
Well, the latest storm tested out my generator hook-up, and it failed. Every time I turned on the breaker on the generator, it immediately clicked off. I tested everything- the genny itself, the cord, the connection to the house. My rig goes in through a 30A breaker, with a mechanical lock-out so you have to shut off the main breaker before turning on the input breaker. My panel is different, because the ground and neutral buss bars are separate and isolated from each other. I'm not sure what this set-up is called, but it is required because my main panel is technically a subpanel (long story). At any rate, the only way I could get it to work was to disconnect the ground wire going into the panel. Then, it worked fine. Any suggestions? I don't like having the ground disconnected, but it got us through a 5 day outage.
