larry4406
Northern Virginia
This is completely disgusting, and now looking back I can’t believe I brought the old filter in the house. Changed the cabin air and engine filters on my sons 09 Elantra, daughters 09 Elantra and my 12 Mazda 2.
And the engineers ensure you have to be a contortionist to replace the filter and charge you out the ***.
No sense in making it easily removable like a furnace filter or air filter on an engine.
Fixr
SW VA
I can replace a door. My drywall patching skill ****.
We have a cat door in the door from the house to the laundry room. The litter boxes and cat bowls are in there. The dogs are too big to go through the cat door.
It works well for us.
I refuse to put a cat door from inside the house to outside, though. Woke up one too many times to a rodent inside the house and the cats playing with it. Rabbits make a gawd awful sound when they're being played with aggressively.
Tiny baby rabbits make a thin high pitched shrieking sound when the sweet adorable kitty has dragged them in through the cat flap and chewed off a hind leg. A hammer was the kindest quickly available choice for the baby bunny. Or it might have been a boot. Don't really want to remember. Cats are obligate carnivores.
terdybukrat
Central NC
i searched before posting, and didn't find a thread like this soooo.......
today, i cleaned up some junk that was in my way. i replaced a bad light fixture, fixed up a tiller, and cleaned up a few things.
how bout you?
Changed engine oil & filter, hydraulic oil & filter air filter & fuel filter on my Kubota b2400…LOTS of oil dry still on the floor
kaymccampbell
Upstate New York
Been there, too many times. We do seem to choose some pretty savage pets.
JJ99SS
Do some quick research on just one outdoor cat's kill radius at night. They kill a TON of things. Little Whiskers is devastating to local wildlife. That said I've had a ton of cats. I watched my Siamese pull a magpie right out of the air as it tried to fly away when my cat made the lunge for lunch. lol
I did the rear drums on my O4 Taco, and bled the brakes. Got coolant to do next.
niget2002
Josephine, TX
I went to investigate. Dog beat me to the sound and dispatched noise maker before I could get to it. Cat and what was left of rabbit was placed outside and cat door was locked closed.
Our cats do a great job of keeping the field mouse population under control too.
niget2002
Josephine, TX
Yup. The house cat is one of the most savage killers in the world.
DGersic
DeKalb, IL
More scope creep on the shed. Decided that this panel on the back was too bad to deal with. Had a few ideas on trying to fix it, but they were all bad ideas, would take too long, with ugly results.
Bought a T1-11 siding panel. Removed the old, cut and installed new.
niget2002
Josephine, TX
Actually in the garage and not in the shop or under the carport...
Installed the new tank mount hardware on the sporty.
I'll cut down the new rubber fender washers at some point... No. No I won't.
I should have realized when I was having a hard time getting the bolt tight without the rubber washers that something wasn't right, but gorilla me just kept cranking down on the nut and bent the tank mounts.
I had to use a flat blade pry bar to bend the tabs back out to fit the washers in.
Axehandle2
And that is why you "bell the cat" if it is going to be outside. It gives the wildlife a possible warning before the attack. Cats devastate the bird population in some areas.
welder4956
Birmingham, AL USA
Today was cleaning out the accumulation of "stuff" in the basement garage. Me and the wife worked on one half sorting through boxes of "stuff" removed from her clothing alterations shop twenty years ago. Part of it was boxes of "stuff" she got from buying out another shop for the equipment. We took one pickup truck load to the donations dropoff and loaded another pickup truck load to go to the landfill. We're tackling the other half of the garage tomorrow, but that side is much less cluttered. Feels good to be rid of all that stuff.
niget2002
Josephine, TX
"cold" front coming in the next few days. Son's lemon plant still has fruit on it. I thought it best to go ahead and bring it inside. Last spring when I left it out during similar temperatures, it dropped all it's fruit.
Once the fruit is finished growing, I'll cut it back for the winter.
welder4956
Birmingham, AL USA
(y)That's what I was doing yesterday, except it was moving plants into the greenhouse and hooking up automatic watering. My esposa has a collection of papaya, guava, bay leaf, sugar cane and banana plants that we bring in before the first cold spell.
Magnum440d100
Indiana
Set up shop out there, to work on the house floor. Finally.
Got the first subfloor board screwed and glued. Got the under house crossover hooked up and spread some goop over it. And a register crudely cut in, for at least SOME airflow/ heat in this part of the house. IMG_4948.jpeg
Only the one in the corner is glued/screwed. It’s midnight, and I have work to wake up for around 4 am. But tomorrow after work, I can glue and screw the others. Start getting this house back to livable condition. I have some more work to do underneath, but I’m hopeful I can at least get the living room buttoned up and ready for winterIMG_4949.jpeg
