YoshiMoshi3
- Joined
- Nov 2, 2022
- Messages
- 502
2014 Acura TSX, Staked Axle Nut
I'm using an older Milwaukee High Torque impact wrench. I can't get the axle nut off. I tried for a few seconds, and couldn't see it budge, so I figured I would stop and concluded it was seized. The nut is supposed to be fastened or unfastened with a 36 mm socket. I'm using a performance brand from O Riley, impact socket, 36 mm, 6 point. The nut is a 6 point nut. It goes over the nut, and there's some slop, but I've used the same socket before to remove the axle nut on the other side without issue. Any tips on how I can get the nut off?
I have a few questions thinking about possible solutions:
1) Would using a higher nut busting impact wrench increase my chances of getting the nut off?
2) Would using a 36 mm socket that is more snug on the nut increaqse my chances of getting the nut off? If so, who makes the most "snuggest" sockets that has the least "slop"? Is this data specified? Can someone provide an example? I can't seem to find where this is specified, for example on Snap On https://shop.snapon.com/product/Deep,-mm-(1-2")/1-2"-Drive-6-Point-Metric-36-mm-Flank-Drive-Deep-Impact-Socket/SIMM360, part number SIMM360. I can't seem to find how "snug" the socket is specified in the specs.
3) Would a shallow, semi deep, or deep socket increase my chances of getting the nut off?
4) Would a weighted socket increase my chances of getting the nut off? I'm not able to find a 36 mm weighted socket.
I'm a little bit concerned about applying even more torque. The last time my impact couldn't remove a fastener, and I used a breaker bar with a long cheater pipe, I ended up snapping the fastener. Could I possibly snap the thruded stud off the the CV axle by applying to much torque? I think I'm less likely to snap a stud with an impact, over a breaker bar.
Right now I'm trying to soak it in penetrating oil. But I doubt that will help.
I tried a 35 mm socket, and it was to small. I wasn't able to find a 35.5 mm socket or a 1 13/32 " (35.7188 mm) socket. Those might be a bit snugger than a 36 mm.
Thanks for any help or tips!
