Less than 10 hours and you are throwing in the towel? Oh the force is weak in this one. Some people haven't even been on since you posted.I guess no one knows..okay thanks
You’re just so fast.lolsaw set
Build a cane kit? You supply the tube.Weighs 6 ounces. The cork-like stuff can be wiggled a bit and might be removable. Seemed to be plumb bobish initially. Extra set of threads means it's part of something. A Google picture search had lots of similar things, but nothing quite right. Surely we'll fine a use for it, eventually.
Part of a Grandfather clock weight? At 6oz, it does seem a little light for that.I was sure this was the elusive Saw Set . . .
What is the ball on yours, almost looks like the recess is for chalking the tip.Mine is a bit different. And what do you do with the stuff you smoke?I was going to do a Blues Clues.
Huh! Better put it out.Mine is a bit different. And what do you do with the stuff you smoke?
I have this exact one and had no clue what the hell it was but I couldn’t toss itThis looks like its also unknown brother, but has lots of more bits on the one face. Does yours have similar bits, or broken off faces there?
Pardon Our Interruption...
www.ebay.com
With the more detailed views in the ebay listing, it looks like a hold down for a vise, similar to a Versa Vise mount. But I've only had 10 minutes, may take a bit longer to find stuff out.
I guess a person could keep chalk in it. But more like a stash location.What is the ball on yours, almost looks like the recess is for chalking the tip.
