Help!
Status
Not open for further replies.
PCustoms
VT
Really odd reason to join and post....
Look at your ordinances and what the requirements are for a a variance (hint: it usually requires "hardship") and go to the meeting to politely voice your opinion.
Be prepared for the neighbor to hate you.
BTA119
Gee, thanks for the ever-so-warm welcome! I was merely looking for friendly advice. Forgive me for asking for some opinions. It would be more helpful if you guided me to a more appropriate place if this is indeed not the right place. The snark was unnecessary. Sorry you seem to be so bothered by my inquiry. I actually thought I could get some kind help. Guess not.
WisJim
Menomonie, WI
If that was the original question, I think that @PCustoms gave reasonable advice. I had to get a variance when building my garage, and I had to explain my reasons in a public meeting that all the adjoining neighbors knew about. No neighbor said anything, so the decision on my variance depended on the people on the committee. I did get my variance, which was for less green space on the lot due to building size, and letting me build into the normal required setback space. If any neighbor would have had a reasonable objection, I would have been out of luck.
To join GJ, ask a question, and then leave in a huff, all in an hour a quarter, seems impatient-- and maybe rude??
The Cobbler
for posterity
My neighbors want to add a 24 x 24 two story, 2 bay gambrel style garage attached to their single level (roughly 20’ x 40’) 960sq foot ranch. My house is the same but has a bit more living space as the basement is finished. The buffer between properties is 15’. They are asking for a variance which will make the front of the garage 12 feet from the property line and the rear will be 2.6’ from the property line. My 10 x 10’ deck is, at most, roughly 15’ from the property line so that is pretty close. We both have reasonably large back yards but this will bring living space that much closer. (There will be no windows on my side of the garage.)
The garage will be 2’ higher than the house. I worry that it will look odd being so much bigger than the house, thus, devaluing my house. Thoughts?
Also, I worry that, being so close to my house, it will be a turn off to buyers should I decide to sell. Thoughts?
They are planning on using the second floor as living space of some sort and the garage will be a place where their cars can be worked on.
I’d really appreciate any thoughts anyone can give me as there is a town meeting in a week or so.
Thanks so much!
jack stand
Lakes Region Maine
Doesn't that seem exactly the nosey neighbor type where the world revolves around him and be first in line to tell you what you can do with your own property!
mrbill55
Greenville, SC
While I think the 3' variance would go through without any issues, getting the new garage built within 2.5 feet of the property line might be a harder press of the variance. Having an elevation difference of only 2-3' is nothing and would easily pass, as long as the materials used for construction, along with the initial design, blend in with the existing structure.
What the OP missed out on was the value of extra privacy being add to his backyard and rear deck. Or, perhaps, even more, a hidden reason for the neighbors to want to build a buffer between his backyard and theirs due to the OP's potentially offensive use of his deck and backyard. In another of our homes, we ended up with a privacy feature, as the neighbors backyard was used for a dumping ground for debris from his landscaping business, making our time on our newly built deck not enjoyable at all. Same went for their children, who we loved dearly, but seemed to lack attention from the parents, and also got dumped into their backyard, not allowing us some quiet time as they sought our attention, or the attention of our company, in a constant manner whenever we were outside.
tarmy
Nor Cal
This thread need to be merged with all those other ones about new members and their need to have their first post responded to in exactly the manner they deem appropriate.😜
NUTTSGT
Northern Central Ohio
I've locked this thread since the OP left in haste. However, he's more than welcome to come back and request this thread to be reopened.
However, reading his post, albeit from Cobbler's quote, he's probably not on the right forum. He would probably be served better on FB or somewhere else that thrives on drama. . . we don't do that here.
Status
