Show your new tool arrivals
SouthernIllinois
Well neither of the Milwaukee XC 3.0 batteries I bought yesterday will go to full charge!!
The charger just keeps flashing red and green.
Guess I'll be returning them :mad:
UPDATE: Removed the battery, unplugged the charger, plugged it back in, all is right in the world again.
will335i
IL
Recent arrivals from Tekton, Cripe Distributing, and HJE, though I won't be keeping them. I acquired 8 of the mini buckets before they went out of stock and wasn't sure what to do with them.. but it turns out 8 is the exact number of brothers, brothers-in-law, dad/FIL, uncles i intend to give gifts to, so I decided to put these together for Christmas! ~$52/bucket
For now they are pretty full, but I'll probably find something else to put in there before I give them out
Can I get a item list. I wouldn't mind recreating this idea for some of my family members.
shoggoth80
Seattle
Minor additions. Got the tie rod tool for a job. Not that I can't pop a tie rod or ball joint with a couple decisive hammer whacks, but sometimes, I don't wanna bash on something. Lol. 17mm Power Torque to fill out the parts store rail I picked up. Cheap, and sometimes I let the OCD win 🤣 24mm shallow impact because I didn't have one, or a 6pt 24mm socket. I have 12pt chrome ones, but I'm not the biggest fan of 12s as a general rule (despite them having worked just fine for many years).
Beerhippie
Far NE Oregon
^ I have the same AP pencil grinder. I find it gets about the same amount of use as my Dremel. I prefer the Dremel for slower speeds, as the pneumatic just doesn't have any oomph at lower speeds.
Most of what I use it for is engraving with a small ball point:
BobsYourUncle69
Westchester New York
There are lots of “proprietary” screwdriver bits, that aren’t really “proprietary”, they’re just a weird standard, designed years ago, before there was much in the way of a “Universal Standard” for screwdriver bits.
Many of these “Weird Standards” are used by multiple manufacturers, and still in production.
While 1/4” hex shank buts are common in the USA, there are still variations, such as “Insert Bits” with the small tiny groove, and “quick change bits” with the much larger round groove for a ball bearing lock (and If I’m not mistaken, there are at least two or more standards for this system with different dimensions).
In addition, there are “Long Shank 1/4” screwdriver blades” used in products like the Facom, and Craftsman, and USAG screwdrivers, as well as some Japanese made screwdrivers.
There are also the “Multi Bit 6 in 1” screwdrivers, with double ended bits with the ball lock mounted in the bits, which GJ members seem to love.
In Europe, hex shank multiblade screwdrivers were common, but 6mm and 4mm shanks seem to have been the standard, and Wiha, Wera, and some other manufacturers still make the screwdrivers and blades, as did Facom in the past, and some Japanese manufacturers.
4mm hex still seems to be a common standard for smaller screwdriver bits.
Even before hex shank bits became standard, there were other standard interchangeable screwdriver blade systems, such as the Yankee (Stanley) bits, which came in three standard blade shank diameters, and which may still be in production. (Although not by Stanley).
Goodell-Pratt had the Mr Punch, spiral screwdriver drill system, which used a standard but different bit type to the Stanley/Yankee drivers.
There are also multiple screwdriver designs that use flags or tabs pressed out of the driver shank for interchangeable bits, but these aren’t always interchangeable amongst each other, such as Excelite and PB Swiss.
There are also small screwdrivers, such as the Moody precision screwdrivers, that have their own interchangeable designs. (I think Moody actually has two separate systems), and one of these systems may be used by other precision screwdriver manufacturers like Starrett, although I’ve never checked.
While I would prefer it if larger screwdrivers had a holder for 1/4” insert bits, it is still not common, and there are plenty of reasons for this.
Some of the other screwdriver systems work better, either for carrying more bits in the same space, or for use in certain areas, such as deep screws in electronics, were even a 1/4” hex blade won’t fit (but a 6mm hex blade will).
Ah , I see, fair enough.
I just wish all them were easy buy everywhere like 1/4 bits are and I've now bought based on that.
I guess they aren't not making it universal for the sake of not making it universal then as my previous writing states.
Thanks for the insight.
Fly Fishing Rick
Upstate NY
I received this Tekton metric socket set and ratchet recently and am quite happy with it so far. The ratchet needed a little tinkering before it felt how I like, but I can be kinda picky when it comes to ratchets... I added some color to the embossed lettering/numbering inside the case to make them a bit easier to read and added some green paint to the sockets to differentiate them from my other and others' sockets. _DSC9581-HDR.jpg
f121
UK
What did you use to mark the sockets and case?
Ohio Andy
Columbus, Ohio
Looks very nice, I really like it
BobsYourUncle69
I do this too whenever there is pop up numbering. Makes life that little bit easier and for some reason I enjoy doing it.
I'm thinking I should change the colour of what I've done , metric blue and SAE red perhaps. The yellow doesn't pop as well as I thought it would
BobsYourUncle69
How bad could these possibly be ? I guess I'll find out when I need to fix a thread assuming it had the size I'll need.
Got these for $9.99 each at a place called tractor supply in stony point ,NY. Intersting place. It's like HF , ACE ,and Ocean state Job lot all thrown into one. They seem to have a lot of house brand tools that are really cheap , especially large size (perhaps Jumbo ?) wrenches and sockets. If I'm in a jam and need a "once off"tool , it's a place I'd consider going to again.
terrific
Sadly, this is probably going back. Wright 6526 3/4" 13/16 socket.
I had big dreams of buying a 40" breaker bar and taking the lugnuts off my car without even bending down. I thought I'd better check if the socket fit before spending the big bucks, and sure enough there's no clearance. Can't get the socket on more than half way.
SC Fly Guy
Aiken, SC & Lakewood, NY
Tractor Supply is a pretty big chain around me and their house tools are on par with what you’ll find at other stores that import a lot of tools. They also carry several USA made brands and have some REALLY GOOD clearance bargains from time-to-time. The clearance section is usually way in the back and is always worth checking out. The last time I was at my local store, they had some nice US made Gerber multi tools for <$15!! [Edited to add - I bought them all!]
BobsYourUncle69
I'd never heard of them before (ive only been on US soil for a year so still lots i dont know ) but I'll definitely stop by from time to time as the pricing seemed decent.
Semi-hole mechanic
TSC has been around since 1938, there are over 2200 stores in 49 states (none in Alaska). I’ve worked at TSC since ‘05 as a TeamLead, an ASM, a Store Mgr, and have stepped down back to ASM since 2019, but I’vebeen a lifelong TSC shopper. It is mainly a farm and ranch retailer, not really a hardware store. Not sure what an Ocean State Job is. TSC’s competition are mostly regional like Rural King, BigR (before they went out of business), Bomgaar’s, Blaine’s Farm and Fleet, Mill’s Fleet Farm, True Value’s Farm and Home, etc.
