Show us your welding projects
danielbuck
Great job.
I had a similar idea while unloading the 4th or 5th load of mulch for the wife's gardening adventures this summer. Problem is she'd get pissed if I drove through her garden beds. So shovel and wheel barrow it is.
I have an idea about making basically a large funnel that can bolt to the tailgate, so that i can park the truck and winch the blade from one of my other 4x4 vehicles, and the funnel would divert hopefully all of the material into a wheel barrow or yard cart (both of which are lower than the tail gate, so I think it should be simple to do). Just winch in until full, then stop, move the wheel barrow/cart of material to where it needs to go, then repeat. Minimal shovel work.
We plan on rocking the front yard, which we don't have much vehicle access to (sounds odd, I know), so this funnel idea may come to life next spring when we do that so we can cart the material to the front yard. :)
jcarapet
Texas
Footrests! Inset a bit from the front edge so the stools can be pushed into the bar.
Yep! I was planning on it. Trying to figure out the angles to do the inset and final design before I move forward.
@jcarapet, have you considered restaurant steam table trays? I did a quick Google and found this 24-gauge stainless one.
It's not the 24 inch size you mention but a couple of adjustments to make the openings 20-3/4" x 12-3/4" could save you some tray fabrication time. I was surprised at the price:
Honestly I had looked at alternate boxes and was flexible on length, but was shooting for an 8" box depth. Honestly I had not seen the 6" deep ones which makes it a real option. Hmmm...
Gutman
ENC
Because I don't want it to roll, it's staying where it's at.
You're a luckier man than I. As soon as I get a box (or something else big and immovable and finally situated), a tiny piece/part gets dropped and manages to bound across the shop and come to rest under or behind said immovable object.
The slate gray is a great color.
NUTTSGT
Northern Central Ohio
Oh, there's plenty of room underneath them for access. However, there are other places for small parts to go Houdini Mode.
I picked up a 27" top box last fall when I had some extra cash to upgrade a different box. Kinda fell in love with the color last fall when I placed the order for this
I don't want to distract from this thread too much but you can check out more about the boxes in the thread in my Sig. (pg 114)
danielbuck
another shot of the blade in action, but this time with the truck stationary and pulling the blade with a winch. Wasn't quite sure if this was going to work, or if my jeep would just slide and get pulled into the truck. This opens up more location opportunities to dump rocks, if there's not something stable enough to anchor to, I can just use a jeep. 4000lbs of rock again.
kaymccampbell
Upstate New York
So can driving through a grove of trees on a bright sunny day... Overhead lights in a tunnel... a long row of guardrail posts... evenly spaced street lights. Bust his chops for little kayak lights? Really?
I've got a special set of dark lenses for my helmet, just for the sun through the trees thing. Makes me feel disoriented when I'm on the bike.
aka Larry
Eastern, NC
That is certainly an inconsiderate thing to do. All that is required is a light. A strobe is extremely annoying, distracting and unnecessary. And can cause epileptic seizures in some individuals.
There is always one.
I figured this might help other motorists avoid putting my kayaks through their windshield, which seems a little more likely than causing an epileptic seizure, but whatever.
BTW, every city utility vehicle here has these same strobes on all four corners, which are on all the time. What a bunch of inconsiderate folks they must be.
PugetDude
Superstition Mountains, AZ
Multiple kayaks through the windshield, evenly spaced, have been known to cause epileptic seizures in certain individuals. Please be considerate of others. 🙄
PhantomEB
Medicine Hat, AB, Canuckistan
Bonus project on a Trellis I built to fit in one of my planters. Still need to primer the legs but in place. I have another one that's a bit more complicated to build, but thats a later project when I get about 15 other projects done.
I want to do this but out of pipe, 32” high so the pipes dig in 16” of the 48.
jcarapet
Texas
I attempted to buy the Swag Offroad finger brake attachment for my box project, but found it couldn't accomplish what I needed. Decided to try my hand at building a bigger brake out of some extra steel I have. PXL_20241204_143304810.MP.jpg
I didn't have enough big angle iron around, so the top piece is a 2x2 square tube (3/16 wall) that I had from a rack build this year. I had to build a jig to cut it with an Evolution metal circular saw. The other half of it I will use to make Smaller sections to act as fingers. Yes, this was a lot of work, but it's still cheaper than the Baleigh magnetic brake I (still) want.
v8nutz
rocklin,ca
Hey, your brake looks a little like my monstrosity! I made mine to bolt to my 1/2 inch steel workbench table. There are things I would do differently if I did it again but I have bent a ton of stuff on it, super handy. I have a couple smaller finger sections for smaller projects too.
Beerhippie
Far NE Oregon
There's something here I'm not understanding.
What is this extra steel of which you speak? Where do I get some?
Beerhippie
Far NE Oregon
Step 1: Have a project
Step 2: Round up a bit on lengths for your order as a just in case
Step 3: Find out you are terrible at estimating and you REALLY rounded up.
My boss seems to think that's irresponsible. Irresponsible as in, "Have you considered alternative careers?"
There are some men you just can't reach.
jcarapet
Texas
Looks like a nice monstrosity to me! Trying to figure out your clamping methodology, or where mine can improve My use of F clamps to hold the top piece is apparently not good enough. Kept walking on a 10" wide piece of 16 gauge which won't cut it for my target project.
v8nutz
rocklin,ca
That piece that goes across the top of the angle has nuts welded in for the bolts that get tightened down onto to little pads on the angle to clamp it in place. I always intended to add an arch piece of steel across the top of it because it flexes some when tightening, but it works as is, so haven't done it yet. I could get better pics but I don't know that my design would help you that much.20190811_154150.jpg
sqznby
Coastal NC
Fiddling with this new machine that I'm not very familiar with. Used an old 30A on a Miller 350 or Shopmaster
Both uphill passes about 38" long done in one pass, not too shabby.
mattthemuppet
San Antonio TX/ Spartanburg SC
IMG_5328.jpegIMG_5348.jpegIMG_5418.jpegIMG_5419.jpegIMG_5420.jpegIMG_5457.jpegIMG_5467.jpegIMG_5469.jpegIMG_5470.jpegIMG_5482.jpegI lent my cheap azz “2t” engine hoist to a friend to load a 2500lb wood chipper rotor in his lathe and the front wheels promptly folded, so I figured I’d make some improvements I’d been planning on making since I got it. Plus it would give me a **** ton of mig welding practice (you can see them getting better, especially after I crack up the amps and slow down the wire speed a bit)
Old Man Roger
Palm Coast Florida
You couldn’t adjust the angle of the piece you were welding? I hate welding uphill, even a slight angle makes me look at other options.lol
Beerhippie
Far NE Oregon
Here's an interesting welding problem: We recently got a new CEO here at the brewery. He's seen some of my welding work and I've done a couple of small domestic projects for him.
Now he's convinced that I'm a real welder! He asked yesterday if I could weld up some drum racks for holding wine barrels for aging ales. I had to explain that I'm a largely self-taught welder, not even You Tube certified, and wasn't too excited about building something with the potential to maim or kill someone, not to mention potential loss of product.
I mean, yeah, I'm pretty damned sure I can weld up a rack that holds ten 50-60 gallon (440-450 lb each) barrels, but not only am I not technically qualified; it might just be cheaper to buy them than to have me fabricate them in my podunk shop (it is).
I'm afraid I've gone down a notch in his estimation.
jcarapet
Texas
What's wrong with pallet racks? He can reuse them later for other things as needed too.
Firstram
My stock response in those situations is “let’s have an engineer get us a stamped drawing and we’ll go from there “!
Huge liability averted
