D45
Universal Portable Band Saw Benchtop Stand
Amazing deals on this Universal Portable Band Saw Stand at Harbor Freight. Quality tools & low prices.
Who has one?
Any solid GJ reviews?
Amazing deals on this Universal Portable Band Saw Stand at Harbor Freight. Quality tools & low prices.www.harborfreight.com
Who has one?
I think that is because he is a ... paid ... promoter ?Why is he hated? I also saw that same video lol.
The hated "Den of Tools" did a review of it and it does look very interesting particularly in the vertical position. One complaint I have is that it doesn't have a clamp in the horizontal position just a stop. I'd have to come up with a way of adding some De-Sta-Co clamps to the unit.
Yeah funny how they are advertising that they "Cut" prices, but the stand is now $20 more...![]()
I picked up one of these in early September when they finally had one in stock at Harbor Freight. I have a cordless Milwaukee Fuel M18 bandsaw.
I want to like the thing, but it just seems too rinky dink. I think I have the saw centered in it and tightened down correctly, but it seems to not make very straight cuts, like the blade moves around too much during the cut.
On my stand, each side of the flat surface that the blade passes through is not on the same plane - there is some twist to it. I couldn't photograph it correctly, but if I put a straight edge spanning the gap, against the fence, there is daylight under it on the non fence side. The gap is the smallest against the fence, but increases in size moving away from the fence.
I have waited and waited for any local harbor freight store to get any back in stock to swap this one out for another to no avail - if they get any in, they're instantly gone. I've talked to a few store managers about this and asked about exchanging mine for a display model, and they were willing to do it, but when I've checked two different display models, they were both even more out of plane than mine.
Also, in the mean time, the price went up 20%, which is probably appropriate, considering they can't keep them in stock.
Anyone else had this problem? Or am I probably doing something wrong or just expecting too much?
I use one of these for mine, just keep the switch locked on.Now figuring out a better way to secure it to the work bench beside using clamps yet retaining ease of removal though it is surprisingly stable un-clamped. Also mounting a separate and more accessible switch.
A good buy in my opinion -- especially on sale.
Yeah, just discussing that:I use one of these for mine, just keep the switch locked on.
Momentary Power Foot Switch
Amazing deals on this Momentary Power Foot Switch at Harbor Freight. Quality tools & low prices.www.harborfreight.com
Thanks for the info!I just got the stand and the Hercules 11 amp portable bandsaw.
Today I took 'em out and hooked 'em up. It took some fussing to get them cutting well. I stopped trying to 'eyeball' the blade in the slot so that it appeared so the same space on one side of the blade, front to back existed, and just made cuts with some 1 x 2's until I was satisfied with the shape of the cuts. I did it only for the horizontal position, I have not done the vertical table mounting yet.
I used several positions for the crossways switch lever, starting at the third from the rear hole (closest to the power cord) for the crossways lever pivot screw. That worked, but the switch lever would hang-up a bit when trying to 'off' the switch. I tried the next-to-last pivot point for the crosswise lever, but ended up locating the crosswise switch lever in the rearmost pivot hole. That would allow the switch to cleanly snap 'off' and to not hang-up, though the two other positions I tried and abandoned, would shut-off the motor.
I like the 6-speed motor switch, but I haven't tried using it on anything but #1 (slowest speed). Maybe tomorrow.
Here's a shot using a square to show the adjustment results I got from using the portable bandsaw stand in the horizontal (chopsaw) position.
One issue I had, out of the box, before I did any frame adjusting (the three big machine screws/nuts for holding the two frame stand pieces together) was having the blade cut a not perpendicular to the long dimension of my wood stock, shape. Think of trying to cut a 2 x 4 with a manual saw, like a Disston handsaw, and not holding it perfectly perpendicular to the 2 x 4. You end up with an angled cut, and not a 'square' cut. That was what I found, and I made adjustments to both the removed front handle and the bracket which replaced it (moving the entire bandsaw forward and backward), and the allen head machine screws which fastened the top frame of the jig stand to the bracket attached to the saw where the saw handle was (moving the front of the bandsaw to the left or the right).
I played with the ~two inch solid rubber biscuits/machine screws which position the rear saw handle left and right, and the allen head machine screws which fasten the top frame of the jig stand to the bracket attached to the front of the saw, replacing the forward handle. When I finally got the saw band cutting perpendicular, if you eyeballed the saw band in the lower frame's space where the blade passes through the saw table, the position of the saw band appeared to be gapped incorrectly. That would be the left gap appeared to be narrower at the rear of the saw table, where the saw band sits, compared to the left gap at the front of the saw table. However, that gave me the cut I show with the square.
I ran out of time today to check the vertical cut function, maybe tomorrow. Right now, I'm watching the Big 10 championship football game. And maybe doing some brief posts.
If you haven't bought a miter gauge already, please consider that the blade is not necessarily parallel to the stand when installed, and most portabands do not have a provision to adjust blade angle. I had an incra miter gauge for my table saw I was excited to use because the slot was the same width as the SWAG table slot, but it was so far from parallel, it was a pain to use. I eventually stopped trying and just got really good at free hand cutting a scribed line.Swag table:
The table dimensions are 9.75" tall, 11" deep, and 13.5" wide, and with the saw installed, the overall dimensions are approximately 22" tall, 18" deep, and 13.5" wide.
That is a very nice piece of kit!Swag table was delivered today
I'll get some pics up this evening
I make my own machine transport stands. One handle works with every mobile stand. These pictures are a sample of what I made.![]()
Who has one?
I've been using this alot and love it
Amazed how cool to touch the saw blade is after use and how good the cuts are
One recent issue......the band saw blade has been jumping off the upper and lower rollers on the saw, when cutting thick steel (1/4"+)
Could the upper and lower rubber rollers be worn? Are these rollers considered a wear item and should be replaced now and then? The saw was bought used.......
2629-20 M18
