gygeneral
In my garage I have a 30 amp 220v breaker in my subpanel, wired with #10 wire, going to 3 -30 amp welder type receptacles.
I just bought a jointer motor 220v, 15 amp motor with a smaller 220v plug on the end. I believe its a 6-20 plug
I would like to simply change out one of the three existing receptacles with the appropriate smaller 220v to match the plug on the jointer.
Is this something I can do? or do I have to either swap out the 30 amp breakers to 20 amp , then the existing receptacles I would have to remove so I don't accidentally plug a tool with a higher than 20 amp load. I don't think the no 10 wire will be an issue.
Thanks
Thanks
