Puget Dude’s creations and fabrications (Random project thread.)
P
PugetDude
Superstition Mountains, AZ
Nice work Scott! :thumbup:
:beer:
Thanks, this was a lot more welding than I anticipated. I finished up the remaining half of a 10# spool of Inefil .030" MIG wire on Tuesday, and was surprised that the full replacement 1O# spool ran out just before I finished welding up the intermediate posts this morning. (Didn't do any welding on Thanksgiving.) Had to exchange my 120 ft2 gas cylinder on Wednesday, interesting observation- the little local welding/fabrication shop exchanges a few cylinders, and his cylinders are filled to 2200#. The local full service welding supply shop cylinders are always around 1800#.
Price is a little cheaper at the little fab shop, too.
P
PugetDude
The panels look great!
What shop did you exchange the cylinder at? Mine is as empty as it gets right now.
Old West Welding on Apache Trail in Apache Junction. Great small business, I try to support him whenever I can.
Let me know if you're going to be out this way, I will let you buy me lunch. 🤣
P
PugetDude
Started on the two gates today.
Gave up on using the new roller for 1" square tube, I need to add a bead roll to dish the inside of the curve to minimize deformation. No time to mess with it right now, so I went old school and kerfed a 5' long piece of tubing @75% across at 2" on center. Pulled it into an arc that looked about right with a bar clamp. Then it was... Weld 26 joints on 3 sides, grind flush, sand smooth...That gave me a nice even curve on the .065" wall square tube. IMG_20241202_160244839.jpg
Came up with a good way to join the 1"x2" vertical frame members to the 1" x 1" arched top. Notched the 1x2 tubing on the portaband table. IMG_20241203_091813707.jpg
Left the side tab a little long for ease of fit up.IMG_20241203_091529227.jpg
More to follow.
P
PugetDude
Looking good scott. Damn good thing flap discs are cheap huh 🤣
Yep, those high quality Walter discs took those welds down quick. Followed up with a fiber/flap disc to smooth out the grinding marks. Screenshot_20241203-200911-337.pngFirst time I have ever used these, pretty impressed with how well they work. Only downside is they don't last very long if you lean on them too hard.
LXCam
Remember what I showed you and Randy. Cutting the edge give you fresh flaps. If you’ve got some sacrificial 1/4 or 3/8” flat bar to use, I find that works as quick as it gets.
LXCam
Very nice Scott and not to poke the dog but you knew someone was gonna ask. How come the mid bar height is different?.
Jayman17
Seattle, Wa
Your fence project really looks nice. When you cut the kerfs to bend that piece did you just do a cut the width of the cutting wheel or did you cut out a wedge shaped piece? Is there some formula to tell you how to space your kerfs?
P
PugetDude
Jay, I cut the kerfs on my portaband table. They are around .040" wide. 26 kerfs works out to about an inch gap.
That's the difference between the inside and outside radii on the 1" square tube, so when the bend closes, the inside radius makes a continuous curve.
Not exactly sure how to figure the exact radius beforehand, this just worked out to what I wanted. If I needed a tighter curve I would have just added additional kerfs and closed those gaps.
P
PugetDude
When I finished grinding the welds on the arch segment, it left fairly sharp edges on the tubing. Instead of rounding it over with a flap wheel, I was reminded of a question that @LXCam asked a few hundred posts ago in this thread about whether my homemade 2x72 grinder had slack belt grinding capability. Turns out it does (on top, between the tracking wheel and the top platen wheel) and did a fantastic job on evenly finishing the corners on the tubing. Much better than trying to run a handheld grinder around the arc.
Thanks, Cam.
P
PugetDude
Nice job on the fence and gates :cool:
Maybe you just found a new part time gig in your retirement. They will call you "The Gate Keeper"
If I tried to turn this into a business it would take all the fun out of it. Prefer to just help friends and neighbors and/or do my own thing.🙂
In fact, just starting on two more welded steel benches for the community. Both with a personal theme for the owners who requested them for the common areas in front of their homes....but they don't know what I have in mind...😉
P
PugetDude
Used the homemade roller bender again today to roll couple of 6-3/4" diameter rings out of 3/8" rebar. They wanted to twist inward coming off the rollers, might have to add a deflector roll in the future to keep the rolled section from rubbing on the bender frame. Also looks like reducing the diameter of the top roll a bit might be a good idea, pretty much bottomed out at this diameter with 3/8" rebar.
The twist wasn't an issue, a couple of whacks with a BFH flattened them right out.
Cut the unrolled heads and tails off, welded the ring and re-rolled it for concentricity.
Satisfied with the results.
More on their application tomorrow.
P
PugetDude
First of three benches I have volunteered to build for placement on the common areas throughout our little 47 home community.
This one is going to be a memorial for a resident who died a month before his dream home was completed😢 His daughter completed it and intends to move here full time when she retires.
Very religious family, so I went with Celtic crosses as the ornamental iron elements. IMG_20241211_145446870.jpg
Had some leftover cast steel knuckles and tubing from my courtyard project that was perfect for the crosses, the rest of the sections were scrounged out of my almost depleted steel inventory. The crosses are supporting the stretcher, so I pressed 1/2" square tubing inside the 5/8 tubing for additional strength; it was a really tight press fit. The 3/8 rebar circles were installed behind the crosses (crown of thorns/circle of eternity?) and also add some rigidity.
I did finally have to break down around noon and head into town for some 1/8"x 1-1/2" flat bar; needed it for the Trex seating supports. Fitted and pre-drilled all the Trex boards, then sent the bench out for powder coating, I want to get it installed to surprise her when she gets here after Christmas. A memorial plaque will be installed on the stretcher. IMG_20241211_145512127_HDR.jpg
Ohmthis
Outside of Louisville KY
Very nice and what a way to honor a person!
fartymarty
Fort Worth
img_20241211_145446870-jpg.2236632
I have to say that you have more than just welding skills. You have a creative talent as well for sure. Had I your welding talent, I would have brought those crosses right to the bottom. However, that would have been a mistake, by stopping them higher and just letting the bottom of the cross hang there makes for a much more eye pleasing aesthetic.
I say that as though I know about such things, I do not. This above is probably only the second time in my life I have ever used the word "aesthetic" in a sentence.
However I know what I like. :bow: 👍
zanyad
NE Ohio
Hear, hear, well said!
That table turned out great, looking forward to seeing it complete and in place.
P
PugetDude
The powder coater doing my wall topper panels and gates called and said they were ready. He was out of town last week and his employee(s) got them all sandblasted while he was gone.
Went to pick them up this AM, my next door neighbor from our Summer place in Show Low was in town and wanted to help with the installation.
Well, they weren't quite ready. 🙄
The intermediate posts and gates didn't quite make the 100' trip across the shop from the prep area to powder coat.🤔 And, they coated someone else's gates Satin Black...😳
Couldn't do much with out the intermediate posts, only one section didn't need one. So, we just hauled the fence sections home; he told us he would have the right gates and the posts done this afternoon. He did, and his work was first rate, no complaints there. IMG_20241212_162747248_HDR.jpg
Went ahead and installed the short section, we are going to do the rest tomorrow morning, my friend Ron from Mesa is also coming over, the 14' and 16' long sections will be a lot easier with three of us. 92' of panels on this project. IMG_20241212_162851964_HDR.jpg
The curved sections fit the wall really well, the deformation from rolling bugs me but no one else will probably notice it. Picture was taken while we were waiting on the missing intermediate posts...it's just sitting on the wall. IMG_20241212_162805529_HDR.jpgWe're having our annual Christmas party on Saturday. 52 guests confirmed so far, it was the impetus to get this completed by this Friday.😅
Cut it pretty close...
P
PugetDude
Got all 11 wrought iron wall topper panels up on the courtyard walls this AM. Three sets of hands made it go pretty quickly.
One gate hung, but the striker side jamb is going to need a little rework. Didn't plan on having to inset the hinge side jamb as deep as we did to get it to sit level, plumb, and flat. Going to have to go to 1"x2" rectangular tubing on the striker side to close up the gap. Not a big deal, but it kept us from finishing up the install today.
Pictures tomorrow, just realized I forgot to take any earlier in the day. Too dark now... 😉
P
PugetDude
Got the striker side jamb on the first gate sorted out this AM. Used a piece of 1x2x.065 wall rectangular tubing, welded four mounting tabs where I had fairly flat stones to drill into. Welded a piece of 1/8" x 1" flat bar on the top and sanded everything smooth. Only put in two bolts for now, will do the other two when it gets back from powder coat.IMG_20241214_142328019_HDR.jpg
This project is (finally) almost done, will get the second gate mounted up tomorrow or Monday.
