Won't the fuzzy dice hanging from the rearview mirror block your view of the tach? Not to mention that it's in the prime location for the bobbling hula girl.
Curious what your long range thoughts for the rear axle are? Pro-Touring type unit bearing floater D60? Strange Engineering drag race 10"? Ranger 7.5"?Not sure I will use this rear axle in the end, so hesitant to put money into it. I don't think is has enough power to break anything at this point! I'll do the work myself, a 9" is the easiest to do. Going to slap a mini spool in the open carrier and install 3.89 gears.
Mike,Awesome Justin. I had an Auto Meter 5" tach in my 1984 shortbed Chevy mounted on the dash when I had my big block in it and B&M Quick Silver shifter for the TH400 trans. I didn't have the shift light on mine though, but it brings back memories.Just before getting married, I swapped the column over to a tilt one with the auto shifter (being my truck was originally a manual trans.) and when I did so, I relocated the tachometer from the top of the dash down to the lower dash just above the tunnel near where the Quick Silver shifter was located prior. More out of sight and less conspicuous than on the dash. But on the dash I think it made a statement like you mentioned.
Likely will be either a 9" or an 8.8. The 8.8 can be narrowed easily and comes with discs. Some type of limited slip.Curious what your long range thoughts for the rear axle are? Pro-Touring type unit bearing floater D60? Strange Engineering drag race 10"? Ranger 7.5"?
FWIW, I've pioneered putting Expedition rear disc brakes (they come with a decent parking brake!) on full float drum brake D60's should that be the direction that you decide on.
Mike,
Was your '84 Chev red? I think you posted some pics awhile back.
Mike,
yes it would. I did think about that.That little Ford would look fantastic painted to match it's big brother....![]()
Thanks. Agreed, I should buy more tools.Nice job on those brake lines. Amazing what good tools can do for your finished product.
Thanks!Justin move that Shift Light right into your line of sight...racers will know you are serious then.
See the light, move the arm. Simple.
Note the location...pointed right between my eyes when in the seat.
Nice ride!!! I would be seen driving it!!!
Honestly the sniper screen is enough by itself. If you have one set it in place to see how it looks, go from there.I am debating throwing a tach in the bronco only cause Speedo will be my Gaia app on my phone, think I got a 2 3/4” one out there on the table. Do I go 3 3/4? Don’t think I need 5” with the sniper too.
Those of us in the peanut gallery require proof of stated comment above...words are erroneous without pics to prove stated double tire incinerator statusNo more one wheel peel.
I just may, Justin. It’s just this thing may see some rock wall climbs that may see some tires heating up. So I like to be prepared. At the very least just stick my little on the column As there’s nothing else there. I do think it will be side by side from my view.Honestly the sniper screen is enough by itself. If you have one set it in place to see how it looks, go from there.
Thanks Mike. It was a challenge to save the carrier itself. One of the cross pin holes was damaged. Luckily this was a 4 pin type, and the minispool uses only a single full length pin. I was able to use the alternate set of holes for the proper fitment.Nice job Justin. There was a substantial amount of wear in there. Nice looking pattern upon reassembly.
I like the Lube Lockers myself as well.
Yes, understood. I was waiting on replacing the distributor, as it could fail at any time, and could be difficult to leave the crime scene.Those of us in the peanut gallery require proof of stated comment above...words are erroneous without pics to prove stated double tire incinerator status![]()
I had a tach on the column of my 77 bronco. You're right, nothing to block view on the dash.I just may, Justin. It’s just this thing may see some rock wall climbs that may see some tires heating up. So I like to be prepared. At the very least just stick my little on the column As there’s nothing else there. I do think it will be side by side from my view.
