Unicorn hunt !
theoldwizard1
SE MI
I am looking for a small, 1/2 ton or less, BIDIRECTIONAL rope puller. Basically a chain hoist for rope, with a lever. Or a come-a-long that does NOT spool up the taken up rope.
Cc_windsurfer
SB, ca
JimH74
South Central Texas
I have a Massdam rope puller. Don't know how to post pictures, but you can google search it. It does not wind up the rope. I think mine is 3/4 t though. Don't know if they make smaller
Beerhippie
Far NE Oregon
I think you're looking for a capstan winch.
Years ago, we used what I recall as being called yankee winches (nothing on these on Google) that were a capstan winch mounted to a chainsaw as ski lifts on fixed ropes.
Loud, slow and heavy to carry while skiing back down, but handy as one could establish a ski run on any slope you had a rope long enough to span.
Old Man Roger
Palm Coast Florida
Huh?
I’ve seen a series of pulleys used to pull a vehicle out of the mud with a come along at the end of the rope, or even just man power at the end of the rope, but never something that pulled the rope with a lever.
Skip ahead to 4:12 to see a smaller version of what I’m talking about.
Wouldn’t what you’re describing require some serious pressure pinching the rope? Probably not great for the rope.
I guess I could envision a system that let the rope out the bottom of a come along type of mechanism, but I could also see it tangling pretty easily.
GeoBruin
A tirfor does exactly that. It can climb along a cable in either direction and because it does not spool the rope, it can be used on as long a section of cable as you can provide.
john.k
Brisbane Qld Australia
When I was a kid,we got a truck stuck and the old man rigged up ropes and pulleys to drag it out.....We literally busted our guts for 3 days ..........I have sure got an appreciation for winches on trucks now.
finn
The UP, God's country
Menards used to carry a small rope winch typically used for things like hoisting your deer on a buck pole at deer camp.
Only cost a few dollars, but has no where to near a half ton capacity
Muckin_Slusher
Abitibi
So, are you asking for something that can pull the rope in both directions?
Need more details, what are you wanting to do?
I needed to pull two ways for the auger lifter I built for a friend.
The pipe in the middle acts like a capstan winch, either rope can get pulled, depending on which way you crank the handle. This allowed me to lift the auger, or put down pressure.
T
theoldwizard1
SE MI
Boat winch or Warn drill winch wouldn't work for you?
Looking for something smaller and lighter duty and less expensive. Also not permanently mounted.
SEGUE - First, sometime I need to plead guilty to the following ! Why do people propose solution to a problem that DO NOT FULFILL THE INITIAL PROBLEM STATEMENT !
I am looking for a small, 1/2 ton or less, BIDIRECTIONAL rope puller. Basically a chain hoist for rope, with a lever. Or a come-a-long that does NOT spool up the rope.
Old Man Roger
Palm Coast Florida
Maasdam Rope Puller.
I've got a few. They're awesome.
3/4 ton I recall (so slightly out of your 1/2 ton spec...) but I've never seen anything similar.
These guys both seem to have solved your problem. It feeds the rope out the bottom.
Beerhippie
Far NE Oregon
Those look really cool. About as expensive as you would expect for something that looks like it belongs on a sailboat, but really simple and slick.
For use on a sailboat, multiply the high price by about ten! Marine bronze is expensive and winches is shiny!
In fact, winch theft is a major problem if you don't moor your boat at a very secure dock facility--like full-time security staff, cameras, locked gates, etc. Bastards will use a cordless saws-all and just rip the deck out around the winch, much like stealing cat converters, but a much higher margin.
Muckin_Slusher
Abitibi
Friggin crabby old *******.
Come here with a retarded thread title (nobody in the future will ever be able to find this thread when they're looking for something similar).
First post is vague at best. Which of those categories are flexible? None? Ok. Good luck.
I find when I'm looking for something and it's difficult to find, it's because I'm trying to do something the hard way. Much easier to NOT reinvent the wheel.
GeoBruin
Okay, sorry, I have a hard time following here. First of all, I've seen the Maasdam puller around forever but never realized it didn't spool the rope. I thought it was just a come along with a synthetic rope instead of a wire rope. It's very cool, and I'm going to buy one, but it does not address the initial requirements of being bidirectional. The only thing I've seen that meets that requirement is a tirfor, but they are not light, and NOT cheap, and use a wire rope, which kind of ***** to work with (I have one).
So was the bidirectional pull an actual requirement or not? OP, have we solved it?
GeoBruin
Load/unload heavy, wheeled up and down ramps into the back of my pickup.
So based on this, we assume gravity will take care of the "unloading" part right? So it needs to be able to control the payout under load, but not necessarily pull in both directions right?
dscheidt
You clearly have a very particular application in mind, but don't want to tell us what it is. So no surprise you get answers that assume you're doing something else.
T
theoldwizard1
SE MI
"Pull" is was a poor choice of words on my part !
I can't be more specific than this !
Muckin_Slusher
Abitibi
You could explain why it cannot spool up the rope.
You could have specified as small/light/cheap as possible instead of giving a hard "1/2 ton max" spec.
So, why can it not spool up the rope?
Why doesn't the maasdam or drill winch work? (too expensive?)
What is the price range?
FYI you can get 1/4 ton lever hoists with 10 foot chains, and I think you can also order the chain if you needed longer.
GeoBruin
Harrington sells a 1/4 ton with a 15 foot chain. Not cheap though. A small lever hoist might be just the ticket. I'm sure jet or even harbor freight has something comparable but cheaper. Those little ones can't weight more than about 5 lbs.
Renegade1LI
long island ny
I bought a few of these, never used then but says it will do what you're asking, see instructions. These are typical in the arborist trades, try looking if they have smaller, but this is a small unit.
