Bbp78
Hi, I'm hoping someone can provide some opinions and guidance. I'm sure this has been asked before several times and I apologize in advance if this is answered frequently. I live outside Philadelphia, PA and built a 16'x24' shop a few years ago for my woodworking hobby. I have a Propane Unit heater, but I never installed it because it needs to be vented through the roof and I need to buy a large 120 gallon Propane tank. During Covid, those tanks ended up increasing to around $1,500 but they are now back down to around $800 or so from what I've seen. I'm not too wild about this heater because it requires me to buy the tank, vent it and then have Propane delivered when needed. I'm thinking about buying an electric heater instead since it doesn't require any of those things. I have recently discovered King heaters KB models in case you were wondering what I was thinking about buying. My concern is that I have 60 amp service and the electric heater may require 30 amps. The only other things I would run while the heater would be on is 1 tool at a time. I have a Sawstop table saw, and other standard woodworking tools. Is this an issue if I install a 30 amp heater and only have the 60 amps? Or do I install one of those DIY mini splits since I don't have air conditioning either? I understand that will be more money probably, but I'd like to try to get this right when I do it. My roof is a little unique as the shop is shaped like a walk out horse shelter with a loft in the front that overhangs the front exterior wall by 4'. I don't know if any of that makes sense. In the back of the shop the wall is 10' tall, 7' from the back wall the ceiling is 148" tall and at it's highest peak in the loft which overhangs the front of the shop it's 15' from the ground. Thank you in advance if you have read all of this and for any guidance you can provide, it's greatly appreciated. I put so much time and money into building this shop, I need to finish this part and make it more comfortable.
