Continuing on with the pedal car.
Saturday morning with coffee in hand, I headed out to begin welding up the crack in the shell under the seat where the rear axle affixes to.
Heat sink secured in place in one of the ribs.
Then low and slow heat was used to prevent warpage and the cracks were welded and hole closed up slightly.
Metal finished and the hold drilled out to the correct size.
And for good measure, I used a well-worn and dirty wire wheel to try and minimize the freshly ground metal look and add to the patina'd look. Not quite sure why, as it will be completely hidden under the rear axle assembly.
Rear axle and pedal linkages installed.
A little lubrication on all of the pivot points to reduce friction and make it both quiet and smooth.
Then for that added touch, a little torque seal was applied. You know, for those critical fasteners that could potentially come loose. Now my grandson can do a quick visual to make sure everything is ready for those high speeds without worry.
Same with the rear axle, Torque seal on the fasteners.
Then the car was uprighted and the steering wheel installed. The steering was terribly sloppy when we purchased the car so with all of the work it is now nice and tight and smoothly operating. No slop in the steering and should be able to hold those high speed turns.
Test fitment of the seat pad so I could mark where to tape for the spray adhesive.
Stay tuned for more pictures..
