Storing a newly machined engine block (how do you prevent rusting)
spyghost
Hi,
I got a couple of engine blocks that have been stripped down of internals.
Basically, oil that's sticking into the surface would prevent rust.
After machining them, it would take sometime before they are again rebuilt. As for storage, getting them wet all over with oil and bagging them in a sealed trash bag would somehow prevent rust, but what about the water jackets? Oil in the water jackets is not a good idea right?
e-tek
Saskatoon, SK
You always spray them down with WD40 and put them in a black garbage bag, sealed with tape. It's not enough to cause any issues in the water jackets and will be diluted in the rad system.
ForceFed70
BC, Canada
When I did this last, I double-baged with garbage bags and emptied 1/2 can of penatrating lubricant (WD40) all over it.
A little oil in the water jackets won't hurt anything.
BillK
Beautiful Southern Maryland
spy,
The biggest thing is to keep them in an area where the temperature does not change much. I have crankshafts that were machined 10 years ago and still look like the day they were done. They are in clear bags with some wd40 but the most important thing is that we keep the shop between 70 and 75 degrees year round. I have seen blocks that were stored in unheated garages and look like scrap metal after 6 months :( Putting them in a plastic bag actually seems to make it worse if there are going to be big temperature swings. In those conditions I almost think you are better off oiling it down and just sitting it in the corner uncovered.
RPH
Michigan Thumb
Cosmoline and other storage sprays are available. These go on thick and jell. Some have a self healing feature if they getwiped they will reflow. Eastwood,woodcrafters and others. Boat stores would have it for winter storage. They work much better than WD40.
Clean up easy too!
2drx4
Northern BC, Canada
LPS makes a great product, I think it's #2... Goes on wet like WD-40, but it dries into a thick waxy film. I use it to coat lots of stuff that I plan to store for a bit. Comes off easily with a little solvent afterwards.
A1an
Tampa, FL
I stored a 302 shortblock on my back porch in FL (covered but heavy humidity levels). I sprayed the bare metal surfaces down with WD40 and immediately put cling wrap over those surfaces (to help keep moisture off the surface and keep critters from crawling inside). Then I double wrapped the motor in garbage bags. Probably overkill but I figured given the harsh conditions this motor would be stored in I couldn't be too safe. Uncovered it 8-months later to take photos for a classified ad and it had no rust whatsoever.
wfochris
VCI bags. That and the LP mentioned above are what Toyota puts their service machined parts (cams, cranks, blocks, etc) in.
trbomax
starvation lake,mi.
I think the LPS is #3.Fogging oil is good, spray chain lube is very simaler to the LPS,it sprays thin and turns to grease.Amsol makes a product called "heavy duty metal protecter" that is also like the LPS.Sit them off any concrete on 4x4's with plastic sheet directly on the concrete under them.Cover with an old sheet to keep dirt off and allow breathing.
NUTTSGT
Northern Central Ohio
WD-40 seems to evaporate after a while. I'd used regular engine oil on the bores, I have one block that I actually greased the bores.
trbomax
starvation lake,mi.
The problem with "regular engine oil" Is that it has detergent additives.These detergents absorbe moisture and then precipitate it out of the solution as a salt.As such,it is hevier than the oil and collects between the oil film and the metal you are trying to protect. Try this............wipe down a clean piece of steel with your favorite 10w-30,then place it in a humid or moist area. Come back in a week. The white mess that is all over it???,thats a precipitated salt of the detergent additive. Leave it a month,and the base metal will be rusty wherever the oil is,still oily,but rusty below the film.
NUTTSGT
That I didn't know. Mine are coated and have a plastic bag over them sitting ona HF mover's dolley. The bag just covers the block and is open at the bottom for them to breath. Luckily in the winter, with the wood burner, it is very very dry in the garage, I have no problem with humidty.
strelnik
Midwest rust belt
Believe it or not, when Detroit Diesel used to store big blocks, they coated the unpainted surfaces with Crisco! Personally, any inexpensive grease works well, keep it warm and apply with a turkey baster brush for 1.00 at the supermarket.
And while you're there, would you pick me up some milk? :bounce:
Bigpigdave
Camden, IN
I would suggest that you wait until you are closer to rebuilding the engines to have them machined. You are correct that oil that is already on surfaces will keep it form rusting, also if any rust did form it would be machined away. Also, if there are any problems with the machining (sizing problems) you are more likely to find them during assembly. It will be much easier to get a machine shop to fix problems if it has not been a significant period of time from when the work was done. Also if you don't have the parts that are going into the rebuild it is almost impossible to machine the engine correctly. Good luck with your projects.
JMO, Dave
APEowner
Sunny, New Mexico
I spray them down with a 50/50 mix of ATF and CRC 3-36 and stick them in a bag with a 125 gram desiccant bag. Last year I pulled a 351w block out of storage that I had bagged that way over 10 years ago and it looked just like it had when I stored it.
