fitter30
Any condensing boiler needs return water under 140° and the colder the better for efficiency. Above 140° efficiency drops to 87% condensation stops. Boiler gets it efficiency from running the condensate through another heat ex changer. Their exhaust can be cooler than the exhaust that's how they can use pvc for exhaust. The only time i used a protection loop the cast boiler was for a process or fed a outside air coil. House usually doesn't have a zone that is big enough to push enough cold water back to it.
