My current drill bit set was bought at Sears about 5 years ago. It's had it... For the post part, I've used this set in the shop on various steel and, of course, on regular ...
Stop using your metal bits on wood!... and using them on wood will dull them.
From what my machinist connections tell me, the Drill Doctor is a waste of money these days. They work for a short period of time, then seem to fade.
Aroo? Seriously? That's news to me. I don't understand how HSS could drill iron and steel just fine but dull in wood? Please explain the causality![]()
Norseman drill bits are the best I've ever used and will probably never try another....it would feel like cheating....lol
It's not as much about the drill bit dulling as it is about the chip removal rate and how easily it drills, which ultimately could lead to a shorter life for the drill bit, i.e. breakage.
There are different point angles for different materials and even different metals. A drill sharpened for aluminum will not work as well in heat treated steel.
While this isn't quite as important for around the house and garage, as it is for a machinist, proper use will prolong the life of your drill bits. Not to mention you're less likely to have to figure out how to remove a busted drill bit.
Actually bits that drill steel are fine for aluminum and they are fine for wood too and even plastic. The trick is turning the drill bit at the right speed for the material being drilled.
Actually bits that drill steel are fine for aluminum and they are fine for wood too and even plastic. The trick is turning the drill bit at the right speed for the material being drilled. Most people have no clue to the sfpm "Surface feet per minute" that different materials require and they spin the bit at the full speed the drill will spin and they dull the bit. I can take a jobber HSS drill bit and make it last all day drilling steel by simply turning it at the right speed and using cutting oil if needed.
The two most common angles drill bits are ground at are 118 and 135 degrees. 118 degree bits need a center punch dimple or center drill hole to prevent walking but the 135 degree will start its own center hole and will not walk.
I have a 115 piece drill index I have had about 20 years and most of the original drill bits are still perfectly good.
I recommend a USA drill index simply because the HSS is a better quality and the grinding is usally better.
I keep a bottle of cutting oil in the fridg too, when drillinng wood the cold oil is thicker and will not be absorbed by the wood as fast!
Thanks, JASTECH
Thanks, JASTECH
Seems like I've heard somewhere about using wax, like you would on wood screws in hardwood. Say that 5 times fast.
Elroy would venture to say that the web thickness and chisel length have more to do with walking around on the start that does the lip angle.
