2025 Garage Sale Thread (14th Annual)
Status
Not open for further replies.
JMP
I spent a few hours rebuilding these ratchets from the last haul. They were both non-working. The Craftsman had gummed up with the old factory grease but the internals were in excellent shape. I ended up using acetone to break the sticky old gunk down since nothing else I had would even touch it. This one was a headache to put back together but it works good now. I'm not a fan of the back drag but I do like how easy it is to access the selector switch.
For the Snap On ratchet (F-710-A) I called Snap On and they sent me a rebuild kit at no charge and I had it within a couple days. This one should have been easy but it turned into a project. I couldn't seem to get this ratchet to function with the pawl they included in the rebuild kit. I compared them and the new one was different than the old one so I decided to reuse the old pawl which looked good enough to use. Since I used the original pawl I soon found out that the new selector switch would not fit as it just slightly too large. I used a needle file to file it down until it fit. In hindsight I should have spent more time troubleshooting with the new pawl but once I seen the parts were different I just assumed things had changed since 1951 when this ratchet was made. Either way it works great now and should easily outlast me.
Yesterday, a map measure with pouch and instructions
Technically, an opisometer! Might as well be using a sextant in the era of GPS-enabled magic in which nobody who didn't go through Ranger school or at least received his Boy Scout land-nav merit badge even knows how to use a compass! :)
Cool find. Germany, I see.
I found and reported one right here on the 2021 thread and then I did a Curator's Corner on them down on the Lugzsonian linked here if you're curious to see mine and read further.
...and a nifty-looking oil can.
Indeed. Also German, I see. Is that just a coincidence? Or did you leave a bunch of bier steins and volksmarching sticks behind in the same place? :)
...a Gray wrench so old it's a Gray-Bonney,...
1933~1961. Nice find.
mikeinri
Nice save (X2)!
I'm old enough that I grew up without GPS, but if I hadn't been a Boy Scout, I doubt I'd have ever learned how to use a compass. This wasn't something they taught in schools (at least not in the 80s)!
Mike
Here is my small haul from day two of an Estate Sale, stopped by on the way home from running the dog. The widow was supposedly 109 when she passed, it was a cool old house, good natural light, on a very deep lot, behind another house. Built on a grade, the garage and house were separated by a breezeway, then a garage like area under the house full of antique furniture, and the detritus of 50+ years in the house. Lived there so long that the assessed value is under $200k, but the neighbor who bought in 2015 is $2.3M. Great neighborhood too.
But anyway, my haul, two toolboxes, a Kennedy Bighorn, and a Rockwell ?Sander? kit box (need to look it up later), plus 2 Yankee screwdriver bits and a tube of Yankee drill bits, and a mailbox lock that may get repurposed into a toolbox front flap lock. Not bad for $10
mikeinri
Anyone else remember "Put Red in the Shed"...?
No, but it reminds me of Robin Williams in Good Morning Vietnam...
Some military brass: "3 up and 3 down, what does that mean?"
RW: "End of an evening?"
Mike
Squez
Southern California
A quick trip to the flea market netted me a 4 dollar handful of tools. Another plomb 1210, snap on ignition wrench, and a broken artisan 3/8” ratchet. I think I can fix it up with some spare sk guts.
On the wayhome I stopped at a garage sale and grabbed a vintage bmw motorcycle tool kit. All the tools are marked heyco west germany except the pliers and the screwdriver, which are ****. IMG_0120.jpeg
Nice find on that 1210 Plomb hard to come bye…. yet to find one
Good flea market day today. I went to two fleas and did pretty good at both. It was a. Blackhawk and Snap-On heavy day. I found the Blackhawk 3/4 rat at one market, passed on the 6 ugly lock on sockets that were separate from it but go with it, then found one nice socket at the other market. :dunno: One of the regulars was wheeling and dealing cheaper than normal on a table of Snap-On he was selling for someone. I ran out of cash quick. He also gave me the wire brush free.
Here is the haul:
-Hinsdale hex drive setup in the tin. Something is amiss as the drive plug is the wrong size for the ratchet but fits some sockets. Need more time to look closer. It did save me a few bucks being the wrong plug.
-Diamond Diamalloy 12” adjustable
-Blackhawk 3/4” push plug ratchet, one socket, 3/8” ratchet, 3/8” breaker bar
-Snap On tin with 1/4 partial set, misc sockets including an old flextension and some clutch bits. 3/8” ratchet and extension, 2 phillips stubbies, puller jaws, battery cable puller, deep socket, flare nut crowfoot setup. Blue-Point cannon plug pliers.
-Craftsman newer ratchet, socket magnet set.
-MTF (Milwaukee Tool and Forge) individual socket
-King **** doe wrench
-3 pliers: Shapleigh’s Hardware, Bridgeport Hardware, S-K Wayne
1AFC3656-2E37-41D5-8601-DDBED00FE734.jpegAD8DC6B6-7631-42B8-8B5C-EFA8D64CE8F1.jpegB34FE904-934A-4202-817D-A55C5A47682E.jpegFFDCB4A0-C75E-41BF-BC81-95BC66D39A17.jpegBE6EE59A-ABB0-4643-A3B6-569107E74075.jpeg
mikeinri
Master Sergeant stripes: three upward pointed chevrons + three "rocker" stripes underneath.
Tom B.
Thanks Tom. I knew it was a sergeant, but didn't want to insult anyone by guessing the wrong level.
Come to think of it, sergeants aren't really considered "brass" are they? (My Dad retired as a Warrant Officer after Vietnam and a lot of years in the National Guard).
Mike
SuburbGuy
Southeastern PA
And here's a few I have no idea what they are.
Top prybar type tool just says Made in USA imprinted on it, Kent-Moore tweezer type tool with 9393-2 and Made in USA stamped on it, blue handle might be for a file??, Etco FT-150 (possibly for carburetor or distributor tuning?), long thin knurled bar with hook on end (broken), KD Tools 413 (can't find anything on this one), red plastic handle tool?, black tool (might be a gasket punch-has 9/16 stamped on it), unknown tool with ball pointed ends??, unknown tool with rollers and what looks like bells on either side, threaded rod with castle nut and grease fitting, mini C clamp with rod on other end, and bare steel double ended hex tool (Hong Kong). Any help is appreciated.
According to their automotive catalog number 74p dated 1973 the KD tool 413 is a crankcase drain plug wrench that fits 8-point drain plug sockets. No specific car model is mentioned in the catalog description. The same L shaped tool pictured on the left halfway in your picture is the same illustrated in the catalog.
DetailSeeker
South-eastern Ontario
That is awesome! I do not know if I will be able to get mine into serviceable condition, but I have high hopes.
Pure coincidence, although it turns out the punch is from West Germany. (Evaporust reveals it has a teeny little triangular flag on it with "TIREM" written inside; further cleaning is necessary.)
Beerhippie
Far NE Oregon
You can still buy them new. Google "Map wheel". Not sure if opisometer will get as many results.
Sorry, but I don't have much hope for you saving that one--that kind of rot on pot metal is pretty much fatal.
I've got several somewhere around the house. Just be aware that miles measured on a flat map do not directly translate to miles hiked on a distinctly unflat trail!
brockmub
Sioux Falls, SD
Picked up this Ryobi level that was going to get thrown out because it didn’t work. Opened it up to find corroded batteries for the vacuum motor and the laser light. A little clean up with DeoxIt and a brass brush, it’s good as new. I used this as a reminder to pull the batteries out of my rarely used devices.
gpw_42
NC Sandhills, USA
***** to:
@neharr41 for his $10 1945 Wilton (and welcome, too...what a way to join the thread!)
@Outlawmws for his $18 1943 USN 7x50s. That's a SCREAMING price for the binos (though not as good as neharr's Wilton...); I've been halfheartedly looking for a pair for a few years, and not yet come across one at my price.
lotus_esprit
I picked up this 1979 KRA-33B for the equivalent of $60. Was covered in decals, removed the majority leaving only the best ones, polished the paintwork. Needs new lock however drawer runners are good, minimal rust. Might remove Snap On oval decal and replace with a vintage Rick Mears no1 decal.
NYBODYMAN
NY
Thank you. Much appreciated!
Skellyii
KC Area
I wanted a roller to mount a vise on so I picked this up at an Estate sale. They wouldn't sell the roller separately, so I had to buy the stack. It was a good price, so I can't complain. Doesn't look like it's ever been used, and it came with the keys.
I would have been happy with a beat-up box, but this dropped into my lap.
JMP
Switch to Lithium disposables and the corrosion issue goes away.
I didn't think of that. I've always just used alkaline batteries. I'm usually really good about removing batteries but nearly had my nice graphing calculator ruined by some Duraleak batteries that I forgot about. Also I have a really fancy Fluke 289 multimeter that I don't use all the time so I am constantly installing and removing the batteries. I guess when it's time I'll be making the switch to lithium.
elmer
Detroit
From a close by estate sale this past weekend , not the best deal but I hate going home empty handed.
2 snap-on ratchets F731A and F720A. Brown & Sharp 4 piece 12" combination square set,
$130 for all.
A Friday Estate sale and I stopped work after 8 hours at 1
What are they going to do? Fire me? cf_rollfloorlaugh.gif 15 days to go!
Not a huge haul, but some interesting tools - makes me wonder what was there at 10:00?
A Walsco insulated and plastic tip screwdriver, Boos adjustable wrench, Bocker arc joints, Klip-tite wrench clamp, almost a ful set of Dunlap DOE's -Maybe I have the Missing wrenches? a well worn plastic face hammer marked MATTICS 29, a Craftsman DOE and a Stanley 203, block plane; Patent date is 10-12-97 and the blade is marked Stanley Sweetheart, and that does not jive as the Sweetheart era was 1919 - 1933, so maybe a replacement blade from the Sweetheart era?
I was half thinking the Bokers were old enough to possibly be contract pliers from ChannelLock, but not similar even to the Champion DeArment type. 5507-7-1/2
The Stanley Plane Parent date:
And "Supplies" mostly:
Eagle oil can pumper, small bulk can but the dual spigot/spout was what made me grab it. Vintage Camel vulcanizing patches - the type you clamp on a tube, and light the "fire cup", a steel shaft and bearing, and a NOS steering wheel cover. There were several of these in different colors. but I don't have any tan interiors..
$10 all
oak_park
Chicago
Its been several months since I've even looked. My sister enjoys thrifting, so we were at a Goodwill shortly after it opened and they rolled out a cart with various stuff on it and I noticed the tools, which I never see there. $21 and change. The cashier was not at her station, so I piled them all up with the prices near each other. I didn't think they would give me the entire 1/2 dr metric set of Craftsman for 99 cents, but she did, she just scanned them and apologized that I had to wait 2 minutes for her to get her drawer opened. Snap on 1/4 metric and mostly complete 3/8th SAE. Snap on CP87 cutters and Vise grips. Indestro ratchets and various usa sockets. I actually left two sets of SAE craftsman shallow and deep for the next guy as I have too many already.
Smokeshow69
Well don’t you just ****!
Beerhippie
Far NE Oregon
SUCKAGE!
Status
