Clark had developed a leak from the hydraulic tank, pretty bad too, turned out that someone had "fixed" a leak with RTV sealant and the "repair" just failed. Between the condition of the tank, the water in the fluid (looked like iced coffee) I decided it was time to do some repairs to Clark. We pulled the tanks off the parts forklift, hydraulic tank is in great condition, fuel tank has a pin hole at the bottom and is clearly rusty inside. I am going to temporarily run Clark from a boat style tank, that way I can use the original tank that is smashed up as parts for the tank that is in better looking condition, but needs to be repaired due to leaks/rust. Both tanks that are on Clark have the sides crushed in and these are a funky shape, so not easy to just make new ones. In the same moment of clarity, I decided to just start fixing everything, so the carb got pulled off, the intake and exhaust was removed, then we took the radiator out. I am thinking that the hydraulic valving is going to get some work done on it too, basically use the parts forklift for all it is worth. Will remake any hydraulic lines as needed and also fix the lights. Even thinking that it is time to put glass in the windshield and maybe even add a wiper. I am sure this will lead to more repairs, but this stuff is long overdo and I am going to rely on Clark in a couple weeks to get everything moved around the yard.
Also spent time and put the tilt cylinders back on the BFF, cobbled a couple lines together so that it functions, but need to make up some steel lines to match the factory ones. Fixed the ignition temporarily and ordered all the permanent fix parts, chased down the alternator and wiring, ordered a new alternator, getting all new belts.
Fixed the ignition on the Hyster at the Hill, it is good to go, next is sorting out the mechanical ebrake.
Looked over the military forklift and chased the wiring a bit, all the lights work, but the wiring to them is abysmal. Ordered parts for to fix the rats nest under the dash.
Basically been a whirlwind and looks like it will continue for a few weeks. My goal is to be ready once we stop getting snowed on and the snow we have is gone. I think this will give me a head start and I won't be subject to mid stream failures due to equipment.
