Is there a good, all-inclusive source for replacement vise jaws?
mark-NJ
new jersey
I have a small Dunlap (Sears, right?) 5244 that's on my welding table, and it fits its purpose just fine. That said, the jaws are pretty worn and I'd sure like to find another set. I've looked high & low and can't find anything anywhere that will fit. Is this size unavailable, or am I just not looking in the right places?
Here's a pic & dimensions:
I can't find anything even close. Nothing seems to have that 2.250" hole-to-hole spacing.
Any ideas?
1982fxr
Phoenix
There is no single source that's worth a ****. Actually there's no single source at all.
larry4406
Northern Virginia
These are 2-3/8" screw spacing. Could you ovalize the hole to work?
KMScott
Well there is one, and he is excellent and a member here! Not sure if he is still doing them.
Calling @KMScott
Mark and Larry. Yes the holes could be slotted but with your dimensions just have Logan Kendrick at Antiquevises.com build you a set. I still make jaws but only for my own restorations. Retired in 2020.
dscheidt
I've made a replacement vice jaw with a hacksaw, a hand drill, a couple files, and a propane torch to harden it. If I were doing that again, I'd use a grinder or dremel to put the grooves in, but it was an afternoon project doing it all by hand.
larry4406
Northern Virginia
I am honored to have had you make a set for my Prentiss! They are awesome and almost too nice to use!
Enjoy your retirement!
WMichelsen
I went through a similar search when trying find jaws for an old 6" TaskMaster vise. I posted about it here:
I ended up getting some cheap pair from Zoro, with workable dimensions, and holes that did not interfere with the existing holes. Then, drilled new screw holes. You'll probably replace the screws, so don't worry about the hole inset being tapered or straight.
Anyway, here's the info I compiled from the sources I could locate. I sometimes found conflicting info, (separated by commas). If you find additional info, add it to the sheet and repost it.
  • ViseJawInserts.pdf
paulsomlo
Northern Colorado
$177 jaws on a $50 vise? Get some aluminum bar stock and some blind hole spotters and get to it - you can make all the jaws you want for less than $3 a pair:
https://www.mcmaster.com/products/b...50/thickness~0-25/width~5-8-1/?s=lauminum+bar
https://www.mcmaster.com/products/blind-hole-spotters/
You can drill and counterbore the jaws using two drill bits, or you can get sophisticated and buy a counterboring drill bit.
kaymccampbell
Upstate New York
Any ideas?
Buy some bar stock. Hacksaw your chunks. Clean up with file. Drill your holes. Break out the file again and checker them. Happiness is.
KMScott
Several jaw makers here, would love to see your work. Aluminum and soft steel hand serrated jaws will do in a pinch but building jaws from Toolsteel and heat treating them will last many years. Here are a few blogs I made on jaw building.
paulsomlo
Northern Colorado
The majority of the time, I'm holding stuff I don't want marred, so soft jaws work well for me. When they get messed up, I can clean up the faces in the mill. Hard to beat for less than $5/pair.
mark-NJ
new jersey
Thanks everyone. I'm beginning to think the only practical answer is a dremel & a file...and re-groove what I have.
slowtwitch73
Hellgate
There would probably be a market for jaw 'blanks'.. steel that had the teeth cut into it, no holes, long enough guys could cut to suit. Few different size runs could cover many bases.
BTL-A4
Santa Clarita
I have a milling machine so I can make my own. I use aluminum since it's softer and easy to machine. I got drawings of all my vise jaws and make a set when needed. I add a rabbet on top so I can hold thin sheets.
Is there a database of the center to center distances? Maybe add one to the vise thread?
Beerhippie
Far NE Oregon
Alternatively, you could just hide the jaws you have:
Made from 1 1/2" type L copper tubing scraps. They also keep welding BBs and slag from sticking to the vise.
