M18 top-off 120v fault
2ndGearRubber
Pittsburgh
I bought the M18 top off about a year ago, primarily to use with my soldering iron. The iron is a Hakko fx600, which I believe has a max wattage of about 65, the top off having 175watt output per the manual.
This worked well for about a year, now the top off seems unresponsive for 120v use. I have 115v AC at the plug, and with the iron half plugged in I also have 115v at each prong. The iron will work on a wall outlet, but doesn't light up at all plugged into the Top Off.
The plug shaped light turns on, and I did plug in a Snapon 14.4 wall charger which lit up, which implies to me some amout of current can flow. I grabbed my Sawzall, I know, and the power supply won't move the blade a millimeter before hitting the overload warning. No idea how many watts a Sawzall wants.
Sounds like my top-off is refusing to move any significant wattage on the 120v side? Warning fault for excessive heat/load doesn't come on connected to the iron. I have used two different xc5.0 batteries with no difference between them.
Odd-job
curious if the fan turns for the inverter. Dead?
At least its easier to warranty than the compressor.
2ndGearRubber
Pittsburgh
Fan is not working, but I frankly don't recall if it ran 24/7 with load applied or only sometimes.
dnschmidt is probably right, and I'll need to send it out to warranty it. It's fantastic to use a corded soldering iron wherever I want.
PCustoms
VT
175W is about 1.5A (I'm rounding).
What's the tag of the saw say?
I bet it's more like 7+
2ndGearRubber
Pittsburgh
I could buy that, I just grabbed it as it was the only 120AC thing I had available that wasn't a charger. Didn't prove a lot to me when it tripped the overload.
