Let's See Your Recent eBay Purchases!
Busted_Knuckles
Northwest Illinois
I picked up this Blue Point 1/4 impact for $20 last week... its no longer a good number so I dont know how well I did $ wise. I actually did not own one of these, I found while looking for a Bostich Pnuematic nailer, same seller had it listed. I works great, and doesnt show allot of use, I was the only bidder, which I thought was wierd.
I know its not a popular tool, I play with transmission, and thought it would be lighter on the hand and arm, than a 3/8s...
Moose-LandTran
The Brink of Insanity (England)
I have a few..
Some hydrometers:
LED Lenser P6. 2x AA size. I love this light, use it all the time. It's extremely bright for such a small light and everything about it is excellent. The fast focus is awesome too.
The P6 was so good i went and bought the P17 too! 3x D size. Even brighter, yet still very heavy. Fits nicely in the hand. It's like a search light or floodlight, whichever you want. Hugely bright! Safe to say i'm converted to LED Lenser.
Athalet trim tool from Germany. After finding the business end was identical to my Wiha one i gave this to a guy i work with.
Sykes-Pickavant diesel injector sockets. 22mm and 27mm
Set of 25 Dormer drill bits. 1-13mm. £55!
Franklin 24mm 12-point deep impact socket for VAG hub bolts.
Stahlwille 27mm, 30mm & 32mm 12-point sockets. Industrial finish. £8 for the 3! Perfect for VAG hub nuts. I only needed the 32mm, but the other two will get used.
Brand new set of yellow Snap-on mini-tip screwdrivers.
Snap-on orange hard Instinct handle screwdriver. I don't own an Instinct screwdriver. Felt like getting one to try out.
Snap-on orange hard handle screwdriver. Not the size i thought it was. :(
Elora 121 10mm x 12mm flare nut wrench. To replace the one that grew legs and walked off. Just like my favourite Snap-on screwdriver. :(
Set of Elora 110 deep-crank ring wrenches. Been lusting after these for ages and have finally given in. Do love my Elora wrenches..
Elora deep 5.5mm 1/4"-drive socket. Needed for stupid bolts on GM pollen filter housings.
Extra-deep lambda sensor socket. Worth a shot, can't be any worse than the one i've got.
SMKS
USA, planet Earth
18 piece Bahco USA socket set. $31 shipped
13 piece Bahco USA SAE wrench set. (I only put 1 in the pic) $54 shipped
1/2" SK ratchet. USA $9 shipped.
1/4" Genius flex head. Taiwan $21 shipped.
3/8" Wright 3490 ratchet. USA $24 shipped.
Not pictured. 14 piece 3/8 drive Williams socket set. Taiwan. $38 shipped.
north
Norway
Three packages this week.
- NOS Bonney oil filter wrench. $10 + $10.
- MAC X8R 3/8" ratchet. $12.60 + $16.95
- New Britain NB-45 3/8" ratchet. Three Husky Pro 3/8" locking extensions. 11/32" no-name ratcheting handle. BIN $19.99 + $10.
Moose-LandTran
I have a couple..
Ingersoll-Rand Cyclone angle die grinder:
Ingersoll-Rand Cyclone stright die grinder:
3M Roloc discs and holder:
Facom fuel line disconnect pliers:
Unior 1/2"-drive Ribe-CV socket drivers (M8, M9, M12, M13 & M14)
Hazet 3/8"-drive deep E10 torx socket:
Laser flare nut diesel injector line sockets:
Leitenberger cooling system pressure tester set:
Stahlwille 1/2"-drive universal joint and extensions and 1/4"-drive 10mm bi-hex socket:
Laser 28mm window-type diesel injector socket:
Snap-on 1/4"-drive 6-point metric universal socket set:
lukiep
UK
Moose what are the roloc discs for i've never seen anything like them before, Also how much did you pay for the pressure tester if you don't mind me asking, been after one of them for ages
Moose-LandTran
The Roloc discs are like surface prep/cleaning discs. They're like abrasive cleaning discs. There's quite a range of 3M Roloc products:
http://solutions.3m.co.uk/wps/porta...ns/3MTechnologies/3MRolocQuickReleaseSystem/#
I paid £200 for the pressure tester kit. You can buy more adapters too to cover more applications. The kit is very nice, the additional adapters are pretty expensive though. One i'm looking at buying soon costs £90..
This is the company i bought mine through:
http://www.international-tool.co.uk/
I was talking to my Snap-on dealer about it yesterday, he said that their kits sometimes go down to about £175 on special. I assume that's the Blue-Point kits, and i've yet to see one on special.
lukiep
UK
Cheers moose, We have the blue point pressure test kit at work and like you say it's a nice piece of kit, I'm looking for one for home use just didn't want to pay snap on prices also i'm on the look out for a vac fill kit aswell
Monte
Germany
@Moose:
wow nice air grinders !!!!!!!!!!!!!!!!!
They´re called "Bristle disc". A "plastic wire brush" filled with abrasives.
Moose-LandTran
@Moose:
Thanks. :)
They're both industrial models. I looked at some "automotive" models but they're more expensive than these two obsolete/surplus industrial ones and aren't built as solid. I paid £100 for the angle one and £65 for the straight one. Both are brand new and boxed. :)
Better explaination than mine. I've only use one a little bit to try it out, seems to work really well. I use my right-angle drill with a wire brush for cleaning flanges and stuff, hopefully this will be better.
Monte
Germany
I always was looking to find some "Cyclone" grinders (Made in USA or Japan IIRC) for a good price.... 100.- and 65.- are crazy low..... (ebay ?)
the cleaning discs work good too to remove paint
surface conditioning discs are also good
Radial bristle disc good for narrow spots
Moose-LandTran
Monte
Germany
ahhh cool thx for the link !!!! 10 available ...good .... hopefully still 1 when i have the £££ :) ....retail more than $400.- ...wow...good deal....
Does the grinder slow down when you push it ?
Moose-LandTran
I only tried it out today, didn't use it properly. I will use it tomorrow and see how it is when actually being used. It's much quieter than i imagined, it also feels very nice in the hand. It's a great little grinder. :)
Tomorrow i'll give it a proper test and will report back. :)
johnnybentwrench
Los Angeles
spv
Stahlwille Series 27 starter wrench set, 10mm-22mm.
That's all for now!
Nice Moose! I wanted the Stahlwille half-moons but could not bring myself to pay the ~$225 + shipping +$80 from Germany. I ended up going with the Facom half moons purchased from the UK. No where near the same "feeling" as Stahlwille, but they do the trick. Did you get them from my friend Michael from ebay.de? :) He sells a lot of Stahlwille and PB Swiss. The shipping is the killer in buying from Germany unfortunately. It seems much more economical to purchase from the UK.
Infidel
oak_park
Chicago
didnt win it, so upset i forgot about this auction, someone got an incredible deal.
Just had to vent
http://cgi.ebay.com/ebaymotors/ws/e...0504035406&viewitem=&sspagename=STRK:MEWAX:IT
sigh
Not trying to pour salt in your wound, but I got this deal from him, used buy it now within 10mins of it listing. 2 sets of Armstrong for price of 1 set of gearwrench not on sale. It was just good timing and luck.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=150505276820
Moose-LandTran
I've wanted a set for a while and recently i've been buying a decent bit of Stahlwille, so when i found these they fit the bill perfectly. I like all these odd obstruction/dizzy/special wrenches..
They may well have been from the seller you know, they came off eBay.de and the seller has lots of PB stuff for sale . (The hose picks came from him too.)
dankicksass
New Jersey
I think I do okay on ebay. Cman thin profile 3pc set, paid a little more than I wanted, about 65% of list, but I wanted em. 3pc Gearwrench magnetic extension set, did great. USA Mac 3/8 speeder, next to nothing. Snap-On JCW95BL-2 new replacement seat, absolute steal. Sure Shot, got that on the opening bid too.
Moose-LandTran
Bought a few things recently off ebay so heres the spoils of war :thumbup:
Blue-Point 3/4 impact socket set
Torque sticks
I knew you'd have some goodies to post. :D
How do you like those impact sockets? My dealer has a set on his truck* and i'm very tempted by them.
*It really is a truck, a 7.5 ton 10-plate Vario!
Mine:
Facom 10mm glow plug socket:
Schley 16mm serpentine belt tensioner wrench:
