Cutting metal barn siding
69supercj
My shop has a metal roof made of the same flat corrugated steel as the siding. I need to trim the overhang back about an inch or so so I can install some guttering. Would a regular old circular saw work with a correct blade and what would be the correct blade for doing this? I've got access to an electric Makita snip/nibbler if that would be better. Just thinking that with all the sharp bends in the material that the shears might be a bit awkward.
bgott
Houston, TX.
I use a regular circular saw blade flipped over backwards. If you do this you want to wear gloves and long sleeves and eye protection. Hearing protection would also be nice, it makes a lot of noise.
PurdueSD
Indiana
What he said, but a metal blade works even better...
jklingel
Frbnks, AK
Depending on thickness, yes, snips or a C6 carbide blade made specifically for steel. Blades are about $45 and come in various tooth-counts for different thicknesses. Absolutely wear eye, ear, arm, hand, and face protection; you'll be getting shards of hot steel coming off the blade.
Bent Nail
piqua, ohio 45356
Depending on the amount of run and availability of ease, a circular saw with a metal abrasive blade is my personal choice . Be aware of paint burn and kick-back.
Good Luck!
Dragster Racer
Morrison, IL
I have been using a Milwaukee nibbler, and really like it. However, my sheets are not yet installed, and I can bend and manipulate them a bit to get the right angle for the nibbler. There are also places, like ripping at the base of the rib, that you will leave marks from the base of the nibbler. For a long straight cut, the saw seems like the way to go, unless you have to purchase the blade. Maybe rental?
hoopty388
Indianapolis, Indiana
ive done these roofs for years and we use a carbide blade turned backwards. a regular wil work but carbide works way better.
using a metal blade will heat it up and mess with the coating and the galvi. it will look fine at first but you greaten the chance of rust down the road.
69supercj
So a regular old carbide tipped blade turned backwards will do the trick. I've got one of those in the saw now. I've got 40 feet to do so I think I'll use the saw instead of snips.
s_ontario
canada
It will rust if you use a saw blade why is it needed to be trimmed ? put up a 5" gutter
use snips
Possum
KS
For just an inch, could you consider doubling up the fascia board to build out the thickness for the gutter? Seems like that might be easier than making that long cut nicely.
+1 If you cut it with a circular saw that edge is going to look like **** and rust, and the hot metal chips will embed in the paint of all the sheets around it too and cause rust spots. I tried the carbide general use blade backward on 29 gauge ribbed panel and the carbide teeth came off in about a foot or two.
kbs2244
I would go one step further and just make the gutters one inch wider.
A 40 foot run is going to be carrying a lot of water and you are going to want “oversized” gutters and downspouts anyway.
JASTECH
Gering, NE
+1 on the fascia board increase. I think it will look better, and be safer to do. A hot metal shard in the eye will leave a longer impression and cost more time, money in the end.
Thanks, JASTECH
Falcon67
Merkel, TX
We had a double wide once upon a time, and I skirted it with corrugated galvi steel. I used a used up regular blade put on backwards in the Skil saw. I cut those sheets longways and crossways, enough to go around a 24x48 with one end 4' off the ground and the short end maybe 18". We lived there 4 years and I never saw any rust issues and never painted the skirting. YMMV. The racket is unbelieveable. Ear protection, face shield with goggles, heavy gloves, long sleeves, etc REQUIRED.
That said - If it was me and it was an inch, I'd double the facia or cut some custom width boards instead of the metal.
Nighttrain
Dripping Springs, Tx
The builders of my metal shop used a small Makita grinder with a cut off blade. I used the same on corrugated metal. Draw a line with a sharpie and go for it. It's a lot easier than a skill saw and a lot safer. It will leave a smooth cut.
kc-steve
Kansas City
Angle Grinder with abrasive metal cutting blade? Someone told me once that an abrasive metal blade used in a circular saw would burn up the motor on my worm-drive. I don't know whether that's true or not. They might have been thinking about cutting something thicker than your corrugated sheet stuff though.
Steve
NUTTSGT
Northern Central Ohio
Steve
That's why you buy a cheap 40 dollar skil saw that you can use for "junk" work. :beer:
Mark H
West Lothian,Scotland
I'd agree with the guys who suggested using an angle grinder.Use the thin,1mm cutting disc designed for cutting stainless steel.They cut fast and accurate,so there's little heat build-up,and a clean cut edge.
Brew62
I would take the whole roof off, extend your shop about 30 feet and put on a new roof making sure the edge is right this time for the new gutter. That should solve the problem. :lol_hitti
shopnut
Florida
This is right out of the installation manual that came with the metal used to clad my ASYLUM...
(click on thumbnail to enlarge)
I try not to drill or grind on any part of the siding/roof that will be exposed to the elements because the exposed edge will start rusting within a month in FL. Shearing the metal tends to pinch and seal the galvanized coating back together on this 29ga material. So far so good, although my building is only about 5 years old.
Just my $.02
