welder4956
Birmingham, AL USA
For motorcycle applications you may be okay due to the low volume of fluid, or ratio of fluid to air. It may still try to compress the volume of air a bit and create some unwanted backpressure when bleeding however.
I would worry about the backpressure pushing an air bubble back into the line as fluid exits.
vwpieces
Hills, PA
Heavy storm from the south would cause water to come in the one garage door. Have a drain inside so haven't cared too much about it and it's not bad.
Checked the edge of the concrete with a level and it was tapered slightly inside in a couple places.
Decided to finally do something about it after 8yrs of being here.
20250308_203113-jpg.2290885
The black line is the door edge outside.
20250308_193633-jpg.2290887
20250308_203146-jpg.2290886
Shopvac stopped sucking in the first 10min, had to get out the cyclone and put it together. Cleaned vac and added water the the bucket. Made it the rest of the way grinding the 14ft doorway.
20250308_202906-jpg.2290890
But this Poor-ter Cable grinder didn't survive.
20250308_202713-jpg.2290883
Fortunately they came in a 2pk for $30. So I went easier on #2. Still have the other 16ft door on the other side to do. These were the only grinders that fit the Hercules dust collector.
2001ZR2
Kansas City
Not much in the garage today...
Drilled 4 holes in the block wall and mounted a grease gun and suction / fill pump storage bracket...
The wall bracket has 4 SS drip cups... Why??? Well, to catch drips of course...
I need to order a flex hose for the grease gun (rigid pipe stores in the handle which I'm not thrilled with)...
My HACK, was to add a .100 thick aluminum panel and attach with pop rivets because I didn't like the window cut-outs...
Hmm catching up on this thread is going to be a little bit costly...Never had seen one and didn't know I needed one but now I have a better way to store my grease guns...gonna order one this week Thanks for sharing this Snip.
16again
Boynton Beach, FL.
Had an accident April 2023. Car came back from repair with a rattle that has been driving me crazy! Finally found it. Piece of plastic that snaps in place between the radiator core support and the condenser.
I'll order the parts tomorrow and reassemble it next weekend. Drives fine and will get me back and forth for the week.
BreeStephany
Oregon
My partner and I moved to Oregon from Montana about 6 months ago and I am just NOW getting a little free time to start working on getting a basic garage shop set up.... need to find a new home for 55 empty Costco totes stacked in the garage, build a work bench out of the leftover 3/4" CDX and 2x6s left over from transporting my roller box from Montana to here and then start finding places for all the things and start building new tools for the new shop to replace the ones I left behind in Montana.
First thing is sourcing a couple of semi-trailer brake drums, 4" pipe and 1/4" plate to build stands for a vise and for a wire wheel and grinder/sander.
My old wire wheel was a dual spindle 3/4 HP 1725rpm Dayton motor with a set of 8" wire wheels, which I am hoping to remake as it worked GREAT for restoring old tools and quickly removing rust from my everyday use tools.
I am on the hunt for an old used Wilton bullet vise, but am not really being too picky at this point so I will take what I can find.
Next is to source a 'decent' 125/250V inverter based mig welder. I still have my Miller 210, Lincoln Idealarc 250 and Miller Dynasty in the workshops back in Montana, but my home garage in Oregon is far too small for these and I have a feeling that while we are leasing our house, the people that own it may not like me adding a 50A 250V recep in the garage, even if I am a licensed electrician.
So that's my project for what little time remains of this weekend.
kaymccampbell
Upstate New York
The HF Titanium 200 welder does 120/240. I've used it to weld 1/2 inch bolts with flux core on 120V at the end of a 100' extension cord. It did fine. There's also a spoolgun available, that I use for aluminum.
kaymccampbell
Upstate New York
Put stuff away.
Trying to figure out the best way to reorg this year.
I've got the same problem. I'm at saturation, and shouldn't be. I need to consume some materials, finish some projects, then go through a major reorg. As it is, my **** is affecting my ability to think. Every place I look needs something, and it's slowing my mental processes by wasting cycles on the misplaced stuff, and not the projects.
PWC Repair
Arkansas
I cleared off a work space to start assembly of a Seadoo Rotax 787cc 2 stroke. Then as I prepped parts I found this snapped off bolt I had to extract. Got it drilled out without hurting the threads too much. Then I used the little propane torch to expand some metal just enough to press new seals and bearings onto the counter balance shaft.
LeonardY
Southern California
I'm in the same boat. I made it worse by getting the new printer. All the stuff from dad's garage too.
This is extended into my house too.
I've become paralyzed.
PWC Repair
Arkansas
Full shop day today, skipped the gym knowing going into the bilge can be full of extra surprises. Old auto/ float switch out, new one in. It takes some abuse in the bilge, its mounted right on top of the "pad" where the boat rides on plane/ at speed. I added rubber washers under the mounting screws to maybe reduce/ absorb some of the abuse it takes. The boat runs low 80's so its no surprise it and everything else gets jarred around. Recovered quite an assortment of random fasteners while I was in there. I'm going to redesign and build the bilge cover plate. Ordered some 1/4 aluminum plate and aluminum group 31 battery trays. It's over due for some attention, I promised myself I'd redo it next time I went in there..here I am.
Last sand/ polyurethane coat for the work bench.
Pictures, no order.
Added one of it sitting in the water for the boat/ fishing enthusiasts.
Oh my gosh bro, just looking at that spaghetti wiring is giving me anxiety. I probably won't be able to sleep tonight.
PWC Repair
Arkansas
Nearly all two-door sedans that have a back seat have longer doors than would be used for the front doors of a comparable four-door car. Access to the back seat of this 2-door Blazer is a challenge for anyone who's not as nimble and skinny as a teenager. The doors are the same as were used on the S-10 pickups, and the passenger's seat doesn't move or fold forward nearly far enough to provide reasonable ingress/egress. Driver's seat is worse. It's pretty pathetic, actually. But it does have three pedals for operation, which was a requirement for me. Me no likey slushboxes.
I've climbed in and out of the back of those many times. I had an '84 4x4 2dr. Then I sold it to build an '88 2wd 2dr with a v8. I still have that one but it's sidelined for now.
niget2002
Josephine, TX
I'm really close to ordering a roll off and just throwing away everything that isn't a tool in the shop and starting over on projects that are either partially done or not even started yet.
GrayFlattop
Chicago
Welcome to my world. This describes my situation precisely.
mopar66
RI
I organized a bit, hung up few things, listed some things for sale on CL. Like Kay, GrayFlattop, niget2002 and others I need to start consuming parts and supplies I bought for projects. I spent some time in the last week organizing parts for one of my mustangs. I spend more time trying to organize than I do working. I did sell off a few things in the last several weeks.
kaymccampbell
Upstate New York
My problem is that I acquired some unexpected materials, and unexpectedly acquired project materials early. And all while enjoying ill health. I was down for at least 5 of the last 12 months, not including the months I spent leaning on the cane. I'm only barely recovered, and easily exhausted.
This year, I intend to try to get last year's projects done, without acquiring any more projects or materials. I almost miss the assdemic. I got so much done, without the world interfering.
mopar66
RI
Getting off track for a minute. But I remember when I would get a new part for a project after saving up or waiting for it to come in after ordering it. I couldn't wait to get it installed. Sometimes late into the night with just a droplight.
kaymccampbell
Upstate New York
Getting of track for a minute. But I remember when I would get a new part for a project after saving up or waiting for it to come in after ordering it. I couldn't wait to get it installed. Sometimes late into the night with just a droplight.
That was up until a year ago. Now, not so much. I need a battery charger for old ladies.
Papa H
Re: what did you do in your garage today?
I recently inherited a million tools so I have been spending the past week going through all of them and putting sets together... I have way too many tools and not enough garage space! Sounds crazy I know but you have to see what im working with! The best part is there is alot of vintage snap on tools so ive been having a blast hooking them up!
Hey, if you help getting rid of some duplicates, I’m your brother in the shop. Heh Heh.
Papa H
Being Sunday, between church and prayer meeting I tore apart the handle on my DeWalt DWS715. I’m trying to see if I can add a DeWalt laser(shadow light) to my miter saw. Any suggestions.
kaymccampbell
Upstate New York
To add to the chain of foolishness. I think I've got too many interests. Gardening, landscaping, home repair, auto repair, carpentry, electrical, plumbing, swimming, motorcycling, metalworking, boating, woodworking, turning, machine work, electronics, CNC laser, stained glass, painting, programming, you-name-it. And all the maintenance n whatnot that goes with them. Most folks I know have one or two things they do. I just can't imagine cutting back.
kaymccampbell
Upstate New York
I've got the DeWalt LED shadow line kit on my chopsaw. It looks like yours , but that doesn't mean much. My DeWalt dealer knew which fit what. I'd call them. If no dealer, then call the mother ship.
