Is the 1/4" tool much smaller than the 3/8"?I like the original, small head nonfuel 1/4”. I also have a 3/8 but don’t use it as much. The answer really depends on the use.
Mostly I use them to work on my BMWs and Porsche, though I sometimes help friends with a Honda or Nissan or VW. If I drove full size pick ups and maintained construction equipment, my choice would differ. What size and torque are the nuts and bolts and how much access is there to them?
Is the lack of torque a hindrance?I have the regular length 3/8" M12 Fuel high speed, not much torque but I like the compactness of the head.
I will probably get the insider at some point as it offers a lot more flexibility in drive sizes and has the extra length.
Not really (IMHO). When I'm using 1/4" it's often in the engine bay when space/access is tighter and I want to manage the force being applied.Is the 1/4" tool much smaller than the 3/8"?
I have the OG 3/8" FUEL model that doesn't have a ton of grump, but I haven't found it to be a problem. I guess it might struggle with a big, long suspension bolt, but I've used mine through several suspension jobs and I can't recall it ever failing to make progress, but have medium and small cars and don't have to deal with any rust to speak of...Is the lack of torque a hindrance?
I own the very same ratchet.Is the lack of torque a hindrance?
Having used air ratchets in the past, I do not think M12 Fuel high speed is weak sauce, it does what it was designed to do.In 1/4 I have the older long neck fuel, non high speed, and a normal length high speed. The HS is basically worthless for anything but clean M6 Threads. It can't break them free with the trigger most times, while the regular fuel which has only 5ftlb more IIRC can do so easily. Rust or locktite, even after being broken free, stop the high speed.
Many places I work, there is no room to swing the coarse tooth head of an electric ratchet, either the trigger removes it or you need another drive tool.
For 3/8 I prefer Snap On, m12 simply isnt comparable unless you want a weak sause nut runner. If the high speed model is all that is available when my regular fuel 1/4 long neck dies, I won't buy another M12 product. Simply not enough power.
Heck I experience "beyond" rust where I live.2nd Gear and I live if different worlds. He lives in Pittsburgh and I live in Phoenix. Out here high speed is the choice, back home in Pittsburgh, the OG Fuel would be my choice or perhaps a DeWalt/MAC as they do have more grunt. In either case the long neck versions are preferable to the standard length versions as they can get into more places. I haven't seen a rusty bolt since I moved here 30 years ago whereas 2nd Gear hasn't seen a clean one possibly in his lifetime.
It’s not a hindrance as much as an annoyance.Is the lack of torque a hindrance?
I generally do this too, but more and more I'll crack the fastener if I know it's not a higher-torque thing. It works better than I expected TBH. Just for the better 'feel', I'll still generally do a final tighten with a regular ratchet if I'm not using a torque wrench.For stubborn bolts I loosen manually then start up the tool.
That’s where you break out the impact gun rather than the impact ratchet.Snap-on Store
shop.snapon.com
If you want the rust-buster - Snap on high torque 3/8. 80 ft/lb, 200rpm, the big dog. That's $730 as a kit with 2 batteries. The snap on stuff in 1/4 has listed power similar to M12, which is why I've stuck by M12 for 1/4 rather than chance upgrading into similar power. If the M12 3/8 HS legitimately makes the same as the 1/4 HS, which per their specs they are the same 35ft/lb, I'm not sure you could even use it as a nut runner in the rust belt. Locktite or any crust would stop it dead.
If you can accept a long neck, the insider makes way more power and gives you 1/4 and 3/8. Although the body of the tool then becomes a bit large for a dedicated 1/4 tool. But it's rated at 60ft/lb, 350rpm, a legit 3/8 power level IMO. The HS M12 tools seem like 1/4 drive power at best, unless you live where you can break something free then spin it out by hand.
It all depends what you want to do, what you want to pay, and what environment you're in. I think the way some people describe using them as nut runners simply isn't realistic on a 10yo rust-belt car. You're not running out an M10 caliper bracket bolt with rust or any locktite with an M12 high speed.
Right tool for the job.
In a professional environment like you are in, beating the flat rate/trying to knock the work out fast - tools will be used and warrantied as needed.It's the same concept as not breaking bolts free with the ratcheting end of a wrench - Cool, guess you're pulling the entire rear subframe for free then. Only way it's clocking onto the fastener is with 4 clicks at a time on a 80+ tooth XL ratcheting wrench, and you're going to pull with everything you have. Gotta do the job sometimes. If I was king they'd stop making nonsense like that.
Agree with that.That’s where you break out the impact gun rather than the impact ratchet.
I have the new Snap-on one and am very happy with it. It is a beast!Snap-on Store
shop.snapon.com
Not in our budget for occasional useI have the new Snap-on one and am very happy with it. It is a beast!
There seem to be so many models, if focusing on one, what would be a favorite for general use?
I can feel an attraction to the insider but can resist due to the price. I have so many socket sets it just seems redundant.
