landrover bodger
norfolk england
went into my garage today to try and do something useful . managed to put 3 wires into the switch on my compressor which is stripped down for a new motor. my grandson is fitting the motor sunday. this is the first propper garage time since my knee replacement six weeks ago so to me a big step forward. my wife was there with me to make sure i did not do anything stupid.
Powderm0nkey
Salem, OR
This is the sort of "unsolicited advice" that should be welcomed by all. A dear friend of mine has been on the list for a liver transplant after his was badly damaged by the toxic effect of alcohol and Tylenol (acetaminophen). Until he told me this, I was unaware of the danger.
Moderation is key. Your liver can metabolize up to 4 grams of Tylenol a day, typically. When you ask it to start metabolizing other stuff as well (alcohol), it gets more fuzzy. Taking a dose here and there with a beer shouldn't be an issue. Regular heavy use, and especially with regular heavy drinking --> now you're talking bad news.
PhantomEB
Medicine Hat, AB, Canuckistan
Made a list of little things needed to tackle some bronco projects this weekend. looking to having seats bolted back in this weekend along with reinforcement plates underneath. Sketched out a box and its dimensions to sink the battery into, trying to keep as much weight down low for climbs.
besides paperwork that needs to be done this weekend, I want that second table broken down and put away in the trailer by end of Sunday.
SMOKEYBEAR
Ran the boat on the hose, all good (y)
While the boat was out front on the pad, I cleaned/ mopped/ squeegeed the shop floor.
Prepared to prep the lawn tractor for the mowing season. Tune up, blades and front wheels/ tires/ bearings on the list.
Wiz02
Southeastern PA
Wife complained that her CTS was making a noise and that she smelled smoke. Car is 14 years old and has only 75k mi. I put the car on the lift and the right inner tie rod boot is wet and the ps pump is growling but the fluid level is NOT low. No other obvious leaks. I saw a bit of smoke rising from area around the tie rod. Of course everything is jammed together and it’s hard to see where the smoke is actually coming from.
Went back in the house to plan my next move. I’m thinking cleaning the boot and a ps fluid flush as a first step. Suggestions ?
Roont
Got both lifts back working. Scissor got a new motor and the quickjacks got a new down relay. One of my ceiling harbor freight retractable air hoses cracked. Got it in 2011 so pretty impressed it lasted this long.
Got some cleaning done and brought in one of the projects to figure out a misfire.
Did a lot of sweeping!
Roont
Push back the boot a bit and see if it's full of fluid. There should not be a large amount of fluid there. If there is, that failing seal may be allowing in some air and causing noise. Some racks can be rebuilt when those seals go. Hope it's the pump for your wallet and free time's sake!
GrayFlattop
Chicago
I took the leap this morning and ran the gas out of the snowblower. Yes we got a couple inches of snow the other day, but it melted away by noon. No forecasted sub-32 temperatures on the horizon, so I’m rolling the dice. Snowblower went to the back of the shed and one set of summer tires moved from the shed into the garage.
While I was planning on swapping the tires, my best friend from high school was in town from Florida, he wanted the full shop tours so we did that, ate lunch and just engaged in “tool talk” - good times! Collectively we puttered and hung out.
Our car days go back to the early 70’s when we had a seemingly endless parade of odd cars between us. ‘64 triumph spitfire purchased for $75 with the engine out- sitting in the passenger compartment along with 2 transmissions, a 63 ford something or other with a “police interceptor” package and tons of rust. A ‘62? Olds 88 hardtop with 3 deuces and a ton of chrome under hood. Several’67 Camaros - all in the span of a few years. We got them all running, did multiple engine swaps and learned as we went along, making many, many mistakes.
Neither one of us had all the tools we needed, so we shared. No surprise that we both ended up in the automotive industry after various different jobs.
It was one of the best days I’ve had in the garage in years.
swsman
Earthbound
Worked on '11 Impala earlier today. Took calipers off, greased slider pins.
Checked it all out while in there.
Also torqued caliper bracket bolts to spec, last time I snugged it tight by feel, glad to say I was close to spec.
After I took the car for a test drive and bedded the brakes some more.
Soon I have some projects to address:
Leaky steering rack replacement (Lucas stop leak power steering fluid has really slowed it down)
HVAC actuators are due
Drop subframe/transmission and replace solenoids/wiring harness (sometimes it slips into a gear).
While I am knee deep I think I will go through valve cover gaskets and other bits too.
Typical GM craptacular quality... This is my moms car with under 92k on the odometer.
Last GM product for this household.
Wrench97
Southeastern Pa
Look above the boot for a leak.
Hooked
League City, Texas
2 afternoons worth of work, $42 O-ring kit later and the 7.3 lives again.
I had planned to spend a day (or so) replacing the leaking o-rings in the oil cooler of my 7.3 (non-turbo). However, after removing the front wheel and cowling I discovered it looked more like a week+ trying to get things off and back together. I decide this is one of those rate times I have a shop do the work.
Boilerhouse
Muskoka
Finally finished building these 6 shop cabinets, a bit under 24 inches wide and deep and about 37 inches high with the wheels.. Drawer construction was a locked miter joint, 1/2 inch baltic birch bottoms, the sides and cabinet boxes were 5/8 inch B.B. Used a natural birch edge banding on the exposed plywood edges. A total of 35 drawers, full extension, 100 lb rating, ranging from 2 inch height to 12 inches. Very solid, but fairly expensive to build. Two cabinets will be fixed under a work bench, the other 4 can roll around, mainly to clean around them. These, along with a couple tool chests that I purchased, should bring some much needed organization to the shop. It will be a week or two to get everything out of their old homes and into the new ones.
PhantomEB
While I grabbed a thing or two of various sized heat shrink I found out after, this stuff actually works pretty good so I plan to swing back in there for 2-4 more containers worth and organize them out accordingly. Gonna have the extra room out there more and more I get stuff done on the bronco.
New Weller soldering gun is being eyeballed too as it comes in it’s own little blow molded case.
today I finish up the wiring to the back and start to really button down brake lines as that’s the next little project After wiring. Once wiring is done that extra foldup table can be put away as well the side workbench cleared up too.
M.Brane
1 hr N/W of LA LA Land
Those "shop cabinets" look nicer than a lot of furniture I've seen.
rd65
Granite Falls, WA
I tried a set of those bushing to bearing steering kits for our YT3000 last season. Jury is still out, but it seems to have made the steering a bit lighter. Wife noticed this more than I did. https://www.amazon.com/dp/B09D8233QY?tag=atomicindus08-20
rd65
Granite Falls, WA
spray on foot powder. clean the area that is wet, then douse with foot powder to find source of leak.
Prospecter
Maine
Dreaded Desk Work this morning, but got out to the shop by 11. Warm enough to open all the doors, and finally dry enough to back everything out. With the sorting, heaving, etc. of the past few weeks, I was finally able to sweep and put away. New coupler on a yard trailer.
Wiz02
Southeastern PA
Just cleaned off the rack, suspension and right side tie rod. Weird thing is that the hoses and the pump are all on the left side, which leaves the most expensive item (rack as the likely culprit).
I bought some magic elixir, (ps fluid with stop leak) but I know that I am just kidding myself.
If it was my car, I would have already bought a new steering rack, but I've learned the hard way that it is better to pay someone to fix SWBO'S car.
NUTTSGT
Northern Central Ohio
We might need more Nap Reports from all of our members.
I still **** at napping, so I'm envious.
There's two kinds of naps. Just a regular nap where you fall asleep and sleep till you wake up.
Then there's power naps. A short nap where you fall deep asleep and get much needed rest in a very short period... setting an alarm if you need to.
At work, I will power nap, I wait till I am virtually falling asleep sitting watching something or the like. I pull my bunk down and set the timer on my phone for 23 minutes. Three minutes to fall asleep and sleep for a solid 20 minutes. Timer goes of, get up feeling rested. Usually a power nap will not screw up your night sleep pattern.
Fixr
SW VA
Power naps are what I really **** at.
PassnThru
Bowling Green KY
Since the middle kid watched me desolder an old shut off valve and solder on a new connector yesterday to install a new dishwasher I got him out in the garage today to teach him how to sweat copper. Thirty plus years ago I had just bought a house and need to fix some piping so I bought some pipe and fittings and taught myself to sweat copper. We cut some of my old test pipe off and I had him solder on some new pipe and a fitting along with a cap and we pressure tested it. It's not the prettiest (cut him some slack - it's his first three joints) but it held - no leaks. His contribution is the shiny stuff on the left. He said he was initially intimidated by it but was surprised by how easy it was. I laughed and said there's a lesson in there for you.
