Bike racks from salvage!
Beerhippie
Far NE Oregon
I had a request a couple of years ago to make a couple of bike racks for a bicycle fest we were hosting at the pub.
We'd recently gotten a large piece of equipment that came in a very large wood crate, and I had some salvaged keg stems and valves, so....
I'd made a rack a decade or so back, but it was crude and gettin' a little long in the tooth.
All the measurements were correct, so I copied those instead of figuring it all out again.
The keg stems and valves (no metal was worked in this project):
We replace those every few years and the value is basically scrap, so we had plenty.
I'm making two of the racks, so gonna go all production on it:
I screwed all the horizontal pieces together, cut to length, then used a couple of block to mark them all at once. Once marked, I drilled though the top two 2X and into the 4X with a long 1/8" bit.
Then the 2Xs get through-bored with a 2" Forstner:
and the 4X gets 1" deep X 3/4" bores:
Repeat.
Parts for the first one, ready for sanding:
Since the wood is salvage, I arranged the pieces to conceal most of the damage--where possible.
Now for paint--six sides--can't do that post-assembly (and it matches the trim on our building):
Finished!
The keg stem/valves are set in epoxy.
In use:
It was so hot that day, the rear tire of the bike sank into the concrete.
Beerhippie
Far NE Oregon
Thanks, folks!
Some points on the design of this rack:
The horizontal/vertical design holds bikes very firmly, but is disk-brake friendly, unlike my first version.
The spacing on the pairs of 3/4" tubes is 3 1/4" OC. This spacing will hold most tires well--your giant fatties can lean against the fence. Spacing large enough for 4" + tires doesn't hold smaller tires well. You can still use the rack for 4-6" fatties, but the tires sit on top of the rails.
Spacing pair-to-pair is 12 5/8" OC, which provides enough room for most handlebars. There will always be exceptions, like California Cruisers.
Just in case you're making bike racks, these measurements work well for me.
For those of you--most of you--who don't have access to used keg stems and valves, 3/4" copper pipe would also look great in this design.
