Ball Hitch for yard cart
Skooterj
Indiana
I have an old yard cart(25 years?) that I use exclusively to haul firewood around from my wood pile to my firepit. Because I over engineer stuff, I put a bucket mount on it to hold fire starter stuff and fishing rod holders to hold my fire poker and log tongs. I'm planning on giving it a paint job this summer. I upgraded the tires to Tweels because Northern Tool has them on clearance and my previous flat free tires developed flat spots. But now I also want to convert the pull handle to a ball hitch, as well as all my mower tow behinds, because I overdo stuff... But the old handle on my yard cart is only like 3/4 square tubing. So how does one attach a ball hitch made for 2 inch square tubing to lightweight 3/4 tubing? Or do they make ball hitches for smaller tubing? I can't find any online. Do I just need to weld a 2 inch tube on the end? Because I **** at welding.
whateg01
doo dah, kansas, usa
Yes either weld a piece of tubing to the handle for the COUPLER to attach to our just weld the coupler to the handle. No, trailer couplers are not made to fit 3/4" tubing. Smh
Bert_
NW Iowa
I've got a little trailer with a ball and I don't like it. I should cut it off and weld on a couple pieces of flat iron. That way I could just use a regular pin.
finn
The UP, God's country
Class 1, (I think) receivers use a smaller square tube, maybe 1 1/2 inch. (Edit 1.25”) They used to be pretty common on minivans. My old Aerostar had one. Towed my I/o 17.5 foot boat all over.
The smaller drawbar might be easier to adapt.
Sounds like a good time to buy one of those sub $100 inverter welders guys have been snatching up.
You could also go with a simple C shaped drawbar the pins on to the back of a lawn tractor.
I think Harbor Freight or TSC has this type of stuff. I’m surprised Northern doesn’t.
whateg01
Class 1, (I think) receivers use a smaller square tube, maybe 1 1/2 inch. They used to be pretty common on minivans. My old Aerostar had one. Towed my I/o 17.5 foot boat all over.
1.25", but I don't think op is talking about the drawbar. I think he wants to put a coupler on the wagon. There's no way to make that not look like a kluged together me. A pin is really the best, most practical way to pull the wagon with a mower.
finn
Probably best to make a new drawbar,
. The stuff a wagon is made with is pretty thin, and not friendly to someone who has never welded before.
In the end, it’s probably to just buy a pin-on 2 wheel composite cart like the Rubbermaid, or is it Craftsman I have sitting behind the garage, waiting for new tires.
larry_g
oregon
Look into what bicycle or motorcycle people use to couple a trailer to the cycle.
whateg01
You mean the handle, which becomes the tongue?
The Cobbler
quite a simple task in my opinion. bolt thru the top of 3/4 square tube , thru the coupler with a couple of 5/16 bolts and call it done.
for added strength , not that you'll need it, shim the sides of the tube & coupler to take up the extra space
kwb
PNW
I just went simple and drop a clevis pin between mower/tractor and the trailer.
Skooterj
Indiana
What don't you like about the ball hitch?
So I went out and double checked last night. The current pull bar of the wagon is actually 1 inch square tubing, but is amazingly thin, and for 25 years old, a bit rusty. And bent... It used to have one of those reversible handles, but that broke years ago. I found a replacement, convertible handle online, but they want over $40 with shipping.
So I think I'll replace it since I'm overdoing this thing anyway. I think I'll just get a new 1 inch square tube a little longer than the current handle and weld a couple pieces of flat stock to the top and bottom with slots for a hitch pin. I need to practice welding on something, so I guess a 25 year old garden cart is a good place to start.
whateg01
That sounds very reasonable. Also a good project to practice welding on.
Stuart in MN
Minneapolis
No need to overcomplicate things. For the amount of load you'll be able to fit in that wagon, you can just cut some wood shims to fit between the hitch and the handle and bolt it all together. It'll be plenty strong enough.
Bert_
NW Iowa
It's a hassle having to thread a nut on a ball and tighten it. Maybe if it was 2 5/16 like everything else I wouldn't mind as much. It's easier to just drop a pin through a hole and be done.
4x4Pete
Stroud
I put a 1-7/8" set up on my yard trailer and lawn mower. I don't use it for anything else. The pin setup was wonky and more difficult to attach vs the ball.
yatg
Southern Oregon
huh? the ball is always mounted to the tractor or whatever you're pulling the cart with. the coupler is always mounted to cart tongue. drop the coupler over the ball and flip the lever.
i find that much easier than dealing with those pin hitches. was always on my knees trying to get the holes to line up so the pin would drop.
i've converted everything to ball and coupler. also added a receiver to my pressure washer and shredder so i can connect a removable tongue with a coupler.
Bert_
NW Iowa
Not my experience at all. The ball has to come out for wagons and hay racks, or to use a clevis . I don't think I have ever gotten on my knees to put a pin in, that makes no sense. A ball is more difficult to line up since there isn't as much slop.
WisJim
Menomonie, WI
I had both a 2" ball and a hole for a pin hitch on my garden tractor. It didn't matter that the pin hitch hole wasn't exactly on center because the garden cart trailer that used the pin hitch never had more than 400 or 500 pounds in it, but I used the ball hitch to pull a big trailer around the yard, move a boat and trailer, etc., so the ball was mounted in the center and the pin hitch hole was a couple inches to one side.
Skooterj
Indiana
Umm, pretty sure overcomplicating this thing is my whole point.😀
yatg
Southern Oregon
OP and most of us are talking about small wagons/carts hitched to riding mowers/garden tractors where the hitch point is a foot or less off the ground.
Skooterj
Indiana
Yes. In this case, a little red garden wagon exclusively for firewood. But I also have a nice 2 wheel dump cart, a broadcast spreader, a lawn roller, a dethatcher, a plug aerator, a 4 wheel dumping garden cart, a lawn sprayer and a lawn sweep. So put one ball on my zero turn, on ball on my old John Deere and hitch couplers on all the implements (9?) and everything is universal and symmetrical. Some things already have 2 inch tubing, but most have smaller 1 inch tubing. Some have built in hitch pins, others don't. So I take out my nice hitch pin and use the attached spring pins on my spreader or sweep and I almost always misplace the pin. I thought moving everything to a 1 7/8 ball would just let me pull up and go. I don't thing anything is even heavy enough to worry about putting a pin through the latch on the coupler. My tractor already has a ball on it for parking my 5x8 trailer. Adding one to my zero turn would be easy, just drill out the pin hitch and screw in a ball.
Skooterj
Indiana
This guy just used some nylon spacers. No welding needed.
reader2580
Minneapolis, MN
The tube that guy attached his coupler to looks a lot more substantial than what a garden cart typically has.
scooperman
modified a yard cart. Dropped the center section, use it to haul the fuel jugs, or haul the start battery to pit lane.
Just turned the hook handle 90 deg. Maybe got lucky with the handle shape, but it never pops out even with the mini bike bopping over rough ground.
Can take close up pics tomorrow if further interested.
Mike65
Horse Pasture, Va.
I got a piece of square tube with holes in it & attached one end to the hitch plate on the back of our ZTR mower & removed the handle from garden cat & attached the square tube in place of the handle. Using a hitch pin & clip it is an easy hook up when needed & easy removal when finished. If you look at the pic the garden cart is standing on the rear & you can see the square bar I use to hook it to the ZTR mower.
