Small Engine Carb Bowl & Electric Starter
D45
NW INDIANA
How in the heck does this 13hp small engine carb bowl attach to the carb?!?!
The hole in the bottom is for the fuel shut off solenoid
Press fit? Twist lock?
I've never encountered this before, usually it's bolted on
D
D45
NW INDIANA
That hole is just where the fuel solenoid is mounted to, there's no bolt
D
D45
NW INDIANA
Here's some pics
It might be a Honda clone? 389cc 13hp
I was doing some motor cleaning and bumped into the bowl and it fell off........
Firebrick43
West central Indiana
The bolt I showed above is broke in half on yours leaving part of it in the carb.
The other half should be able to be pulled off the solenoid if it’s not frozen. You will have to extract the other half out of the carb
D
D45
NW INDIANA
Lovely! It's rusty and dirty inside.
Might be worth an entire new carb if it's that brittle
D
D45
NW INDIANA
For $30ish I may as well just order a complete carb
The bowl was full of junk, even though it ran and started
I need to pull the electric starter also and fix the electric start feature
BillK
Beautiful Southern Maryland
Just want to add that the last 3 "aftermarket" (cheap) carbs I got did not work worth a darn and ended up replacing them with OEM for not that much more. One was for my snow thrower and the other two were for a couple of leaf blowers I was fixing for friends.
D
D45
NW INDIANA
Japanese Standard is the OEM carb product for $57 shipped on Ebay
Amazon no name carb is $23-$33 shipped
D
D45
NW INDIANA
I found the carb bowl bolt for sale, it's like $23 plus tax and shipping!
I'lll probably need a carb bowl gasket also that's around $10 plus tax and shipping
I'm going to pony up and just spend $55 for the OEM carb, that comes complete with a new fuel solenoid
D
D45
NW INDIANA
D
D45
NW INDIANA
Here's the damaged starter
D
D45
NW INDIANA
This Amazon link for the 338-459cc starter looks to have way to large of mounting bolt spacing:
This link for the 240-301cc starter looks close
I just do not want to pay alot for the starter and figure there has to be a more universal starter available for this PT1300EG engine
firebirdparts
Kingsport, TN
My experience with lower priced knock-off starters is that if DB electrical doesn't have it, you don't get it.
This is their version: https://www.dbelectrical.com/products/honda-starter-9-9hp-gx270-31200-zh9-003-128000-9400.html
I am basing that on looks not the description
Okay well maybe I'm wrong. Found this under ATV's.
D
D45
NW INDIANA
Well lesson is, measure twice.......or five times
I don't think I zero'd the calipers when I measured before?
I checked the block and the old starter this morning
It's definitely closer to the 84mm of the 11hp-13hp starters online for a fraction of the cost of the OEM unit
Again this is for a 389cc 13hp engine
OccupantRJ
Eastern North Carolina
Get a measurement to the outside edges of the holes, then subtract one hole diameter, will be accurate. Alternately measure inside edges, then add one hole diameter.
D
D45
NW INDIANA
I took off the stock carb and ran it through the ultrasonic cleaner. Looks great!
Now if I can find a replacement carb bowl bolt for the fuel solenoid that isn't $35 and coming from the UK
D
D45
NW INDIANA
This seems to be the replacement bolt, but I cannot find a part number
I would assume this bolt can be purchased separately from having to buy the entire carb assembly
firebirdparts
Kingsport, TN
I will admit I was looking at the scale on it and scratching my head....
D
D45
NW INDIANA
A GX340/GX390 Starter Motor was a direct replacement, fit perfectly
It also cross references to the Predator, Generac, Duromax 389cc 420cc 439cc
petty much a universal starter for 11hp-13hp engines
D
D45
NW INDIANA
New air filter, gasket bowl gasket and bowl bolt should arrive today
I wanted to keep the carb OEM and not risk issues with a $25 Amazon carb, so I took it all apart and just threw it in the ultrasonic cleaner
It ran great before the bowl bolt broke so I'm hopeful it will start and run great this week......
Fresh oil
New spark plug
New air filter
New starter and solenoid
New fuel filter
New 12V battery
Bought it for $80
hobie18
Emulsion tube clean?
I thought you ordered an oem carb?
Post 22
Lookinh forward to it starting, next post
D
D45
NW INDIANA
I did initially order the carb but returned it after it arrived and I noticed several design differences
I had to order the bowl bolt from the UK!!!!!
I feel better knowing that the motor will run with the quality OEM carb
