Contamination-Oil in 20 volt battery
AC-WC
NE, Indiana
Accidentally spilled chain oil in a 20 volt rechargeable battery. I've tried draining it, wiping excess, spraying with cleaner into the holes.
Should I even try charging it or just write it off?
dnschmidt
Phoenix, AZ
Oil typically doesn't have a problem with electricity. All power line transformers are filled with oil and your automatic transmission immerses electronics in ATF. I don't think it will affect anything except catch dirt.
u3b3rg33k
i'd be more worried about spraying cleaners in the pack than the oil, myself.
A
AC-WC
NE, Indiana
I used Mass Air Flow sensor cleaner for cars. Assuming it was safe for 'electrical' stuff.
PCustoms
VT
I don't think I've seen a battery case have any openings got a picture?
A
AC-WC
NE, Indiana
I've kept it this side down since yesterday and it's still oozing after 2 healthy doses of MAF cleaner today.
Beerhippie
Far NE Oregon
Blow it out with an blowgun on your compressor. Oil shouldn't hurt anything in a battery--just be messy.
Just be glad it wasn't beer!
A
AC-WC
NE, Indiana
Yeah beer and chain saws don't play nice together. I cut about 60 ft of honeysuckle along mom's 1/4 mile driveway. 1280 ft to go:oops: Maybe it will go into the charger easier.
Thanks guys!
david3921
Wyoming, Michigan
I would open it up and clean it out. It's basically three components; top, bottom, and battery pack. Just don't have any metal nearby to short anything.
Hyper Tough?
MOS3522
Colorado
Is it worth the risk over a battery worth 50-150 bucks? There are many many stories of lithium tool batteries burning down homes without the added risk of having flammable liquid residue inside the battery case.
Rabid Badger
1) Open it up.
2) Spray it down with electrical cleaner.
3) Blow everything off with compressed air.
4) Reassemble.
:willy_nil
Beerhippie
Far NE Oregon
I've used this to clean out electric motors that were gunked up...
Designed for and works while the motor is up and running...
Would think it might be a good consideration for your situation...
That stuff will absolutely destroy many plastics! I used some to try and clean out a dirty USB charging port on an MP3 player and the case crumbled afterwards.
CRC makes an Electrical Contact Cleaner that is plastic-safe.
A
AC-WC
NE, Indiana
I will try that this weekend, unintentionally booked for the next 3 evenings. I did notice the screws on the bottom of the battery thanks for the video.
A
AC-WC
NE, Indiana
Update-It was still daylight when I got home so worked on it tonight. David 3921-that's the same battery and amperage! I pulled the screws out and sprayed/wiped about 4 times including blowing out with the air compressor. Still has oil but got the lions share out. I thought they had some kind of circuit board and that is what I was afraid of goofing up. Put back together, stuck it in the saw, functioned like normal, stuck in the charger and it's still OK. I will mark this one to make sure I don't leave it charging while I'm not around just to be super safe.
Beerhippie
Far NE Oregon
Oil is not an electrical conductor--unless it was really dirty. The amount of combustibles a film of oil will add to a lithium fire is insignificant.
I'd think of it more as corrosion prevention.
xjfish
I've done this many times, unfortunately, with zero long term issues thus far. (batteries and tools) I do use electric contact cleaner liberally, followed by compressed air. Let it sit to allow evaporation. Plastics may become discolored, depending on what cleaner used.
