nadogail
Cleaned the Squeezed out glue from the last batch of legs I assembled.
A Flap Disk in a 4 1/2” grinder saves a lot of time and effort.
I’m not going to spend a lot of time and money trying to make things Perfect or Pretty, many of my light fixtures are efficient and inexpensive.I've been looking for a light fixture for over the miter saw area. The problem is I don't like the look of standard shop lights, and I'm toocheap "fiscally responsible" to buy a nice looking one. My solution was to make a box out of scrap wood and paint it black, then mount the inexpensive shop light in it. Now I just have to figure out a solution for the cord dangling down....
Nor I. Jack's and ramps. In the last year or so it's started to wear on me, laying under vehicles. Been looking at lifts, but so far thats all I've done is look. Embracing my inner cheapskate.Since I don’t have a lift, I am disinclined to investigate further - embracing my inner sloth.
I feel a close kinship with both of you right now.Embracing my inner cheapskate
You CAN have efficient, inexpensive and attractive. It's not hard, just time consuming.I’m not going to spend a lot of time and money trying to make things Perfect or Pretty, many of my light fixtures are efficient and inexpensive.
Nicola Tesla, here we come.
Great use for a 123 block!
Wow, now that is goals. That looks very clean. Did you paint the pipe?Thanks to a friends help with the wiring and plumbing the Transair lines, I finally have compressed air.
The compressor was delivered about two months ago, but due to a multitude of reason, we just got it wired and hooked up this evening.
Makes 24cfm @ 175psi. Fills the 80 gallon tank from empty to 170psi in about 4 minutes.
No leaks in my redneck cooler/water separator, the Transair plumbing or the three regulator/filters at each drop.
The green light on the exterior of the tool room tells you the compressor is energized, the red one tells you the Milwaukee and Dewalt chargers are energized so I don’t forget to turn them off at the end of the night.
I seriously need to do mine as well. Maybe I can can everything to fit.Upgraded welding cart
Now you know why the Egyptians walked funny.. I moved it in by myself using secrets of the ancient Egyptians. My back feeling it now.
Bought what they called a potting bench at an estate sale.
Nice!
Fingers crossed for you, but there is a tool for that..I just hope I don't need to un-solder some of the other parts that have multiple soldered pins... That will be a nightmare...
All the above, keeping in mind that it’s not under load.Nice!
Having an engine run stand like that, what exactly are you able to accomplish?
- Break in cam?
- Adjust timing?
- Check for oil leaks?
Still recovering from the work on my kids Jetta, but wall cabinets (cheap unfinished Menards ones but they'll do) are going up FINALLY. This is my first attempt ever hanging cabinets and I'm happy so far. No stud on the left side of the far left cabinet so I'm going to shore the gap and go into the side wall instead.....probably will leave the furring strip there along the bottom since the lights will hide them after the fact. I'll tinker some more after dinner tonight and tomorrow I'm going to try to get the big cabinet torn down and moved so I can get the other two in. They're 33" wide each and the wall span is 135" so it's a pretty good match.
