stonesfan68
Houston, TX
Garage adjacent in the laundry area, 'rebuilt' the clothes dryer. I had replaced bad rollers, belt and pulley several years ago with a cheap eBay or Amazon kit. Started making some lovey grinding and squealing noises on the past couple months. So, I got a factory kit, spent a couple hours disassembling, cleaning and reassembling the unit. Nice and quiet once again.
We have that same dryer! I don’t buy anything but genuine Whirlpool parts for it. It just isn’t worth it to me.
GrayFlattop
Chicago
House, not the garage. Rebuilt 2 of the “frostproof” outdoor 1/4 turn sill ***** on the house. It seems like the rebuild kits only last about 2 years before needing a new washer and packing. These are Prier made in USA units that were not cheap from Menards. I that I always drain them every fall before first frost. The Nibco one at the other end of the house has only needed one washer replacement in the last 45 years. Planted a few perennials and admired the daffodils.
Then I spent a few hours tracing in-wall coax (labels were faded) and removed some cables from the wall that were no longer used (component video from the tv to the rack where the pre-hdmi equipment was). Mostly a clean-up project as our trusty plasma set is going somewhere else (free if anyone wants it).
In the garage, I did use the table saw for 30 seconds to cut up a piece of Masonite, put a few tools away and puttered for a while longer.
M.Brane
1 hr N/W of LA LA Land
Made some more progress on the HF bandsaw. I added some wheels, brackets to hold the power cord, and a new stopper for holding the saw vertically. I don't plan on using it in vertical mode but I wanted something better than the original setup it came with for when I need to service it.
Nice! I use mine in vertical much more than I thought I would once I had a nice solid stand instead of the flimsy stocker.
DGersic
DeKalb, IL
Pressure washer slidey wand thing wouldn’t slide between Low and High. Took it apart, Found nothing really wrong, probably just some corrosion in the moving metal parts that look like they’re brass plated steel. Added a bit of Sil Glide, and reassembled. Now it shifts fine.
Got the pressure washer running, and found that with the wand in Low, the soap sucker siphon tube does, in fact, ****.
Since I had it running, I used it to blast off some paint drips and spatters on the driveway from painting the house last year.
Then I took my lawn mower apart.
More to come on the mower refurb project later.
swsman
Earthbound
Why did you alternate the direction of the panels?
This is how the original panels were, and other fence around the house is done the same way.
As explained by a neighboor, it is done so if there is an emergency fence could be climbed for each side. Not sure how accurate that explanation is.
coldh2o
Ontario, Canada
There is always debate on which neighbour gets the "good" side of the fence. Maybe this was someone's solution.
The average person could not climb a fence like that to save their soul.
This is it exactly. around here this is called a "good neighbor fence" and is standard.
swsman
Earthbound
I told my neighbor I would just toss something heavy through the panels and walk on through:)
Two regular size fellas heaving into it could take it down no problem.
It was lot of work, I primarily did it solo. Glad to be done with it. Onwards and upwards...
SouthernIllinois
Started on restoring Dad’s vise I found when we moved back.
Not certain but I believe this was one of my Grandfather's vise before Dad got it.
Not sure which Grandfather - they both grew up and lived here their whole lives.
Got the moving parts broken free.
Let it soak in Corrosion-X overnight, pressure wash it, sandblast it, paint it and put it back to work.
Screenshot 2025-04-15 at 6.07.07 PM.pngScreenshot 2025-04-15 at 6.07.17 PM.png
Once I'm done with it, I am going to use a hitch type mount welded to my new table.
LeonardY
Southern California
Gathered more tools to work in the yard. I did it several times. They last time I grabbed my tool bag so I could throw all the tools that I brought out individually.
Put away the tools I took out to the yard.
Of course, I couldn't find a 10mm socket. I grabbed this socket set out of my truck that I took from my dad's garage while cleaning up there.
It was mine and i left it when I moved out in the 1980's I'm pretty sure my sister gave it to me for Christmas.
Found the 10mm socket in there.
And then I noticed this.
That wasn't part of the set. Thanks dad.
rzims
Grass Valley, CA
Rehandled an old Craftsman hatchet I've had for at least 30 years....was our camp ax for years.
Then started on a busted maul that I've had for many years as well. Not sure where it came from or when I got it, but I feel like I've always had it....
I'm going to rehandle this one with another nice wooden handle
Cut a piece of Ply down for a "Mouse pad table" for my daughter's use in her easy chair, as her L-tops touch pad died. she is determining final placement on the tin can support before we finalize. (can goes into the drink holder on the right)
A little yard work.
The rest of the day was mostly insurance, but got that sorted.
DGersic
DeKalb, IL
This morning, hauled the lawnmower parts and the pressure washer out to the end of the driveway, and blasted all of the stuff off of the deck and small parts.
Found this piece was broken. Not sure how that happened, it didn’t seem an obvious place for anything to hit it.
Contemplated buying a plastic welding kit, or one of those staples kits to fix it. On a whim, checked with the local dealer to see if this is available, not really expecting it to be.
Not only available, but they had one on the shelf, and for $16 it’s now mine. Cheaper than trying to fix the broken one.
This evening, I reassembled the glove box hinge with some new rivets.
Then modified my replacement door to fit the lock/latch.
The door is supposedly a 1937. The latch is supposedly 1937. I’m no expert, but these clearly weren’t meant to go together. They do now.
Installed my painted hinge and a new repro glove box. The door fits, but needs a couple of rubber bumpers for the bottom. Ordered those, should be here in a few days.
kaymccampbell
Upstate New York
It's a vibration crack. The metal is under stress from stamping and it was just waiting to relieve it. It'll weld up just fine.
DGersic
DeKalb, IL
It’s molded plastic. Fits over the rear axle, provides the back portion of the mower deck, and part of the bag chute. The broken part is inside the bag chute.
Anyway, $16 is a cheap fix through replacement.
swsman
Earthbound
Finished the hat/coat rack last night, used another scrap piece of cedar picket.
Decided on simple nail hanger vs something fancier, drilled them in at an angle - no epoxy needed these are not going anywhere.
rd65
Granite Falls, WA
Nice find. That stubby ratchet is worth more than that whole Allied set.
PowerWagonBuilder
NW of Richmond, Va
Got to use my 2" diameter End Mill. This thing was "desk art / conversation piece" 6 years ago when I acquired it. Friends with me the day I bought it were like "what do you need that thing for?" Its "Cool" was an okay reason then... but now I own a machine to turn it and got to use it for milling a radiused pocket for a coil-over in a set of trailing arms.
kaymccampbell
Upstate New York
Wow. It's so sandblasted that in the photo it looks like metal. Vastly different from the picture below that I never guessed they were shots of the same part.
