rdaleyj
Can anyone explain scope testing the rotor air gap?
I can tell ya how Elroy would do it at the drag strip with a timing light.
Sounds like a fairly normal pattern. Burn time should be between 1.5 and 2ms, so you might be a little on the short end of things, but that is because of the high firing kV.Wow that was a definitely quick answer thnx. Im using a Fluke 199c with a 10,000:1attenuation ignition pickup, and while the firing lines are kinda high, the spark kv stays around 2kv and burntime is 1.6ms to 2ms. The vehical is a 1990 Ford e150 van 5.8 liter.
got an amp draw of 5.2 amps.Sounds like a fairly normal pattern. Burn time should be between 1.5 and 2ms, so you might be a little on the short end of things, but that is because of the high firing kV.
You might still be a bit off on the fuel pump. 60,000ms / 14ms = 4285rpm which is a bit on the slow side. I'd check the amp draw of the pump, and if it's higher than 7.5A or so, you probably have a plugged fuel filter. That could be part of the reason for the high peak kV. If you have a low amp probe, check that pattern as well.
