Decisions are made, winter is coming, I'm ready to go.
Background: I have gone back and fourth for a few years now as to what kind of floor to put down in my garage. At one point or another I have contemplated just about every option out there. My choices came down to epoxy for it's durability, or VCT tile for it's looks.
Next week we close on a brand new house that has an over-sized 2 car garage and a free standing 1 car garage. Now I realized I no longer have to make a choice! I will epoxy the 2 car garage where the cars will park, and tile the 1 car garage which will be used as a workshop and as a home for the kids' bikes. Here are my questions:
Epoxy-
Acid Etch: I am a little confused/concerned about the acid etch. Do I need to neutralize the acid after applying? I have seen several threads about this. Some say neutralize with baking soda. Some say the rinse water neutralizes the acid. Any advice?
What about the mixing specifications? Should I make a stronger batch to get a good etch?
Also, I was in Lowes the other day and saw 2 kinds of acid. Both the same brand. 1 was "green" and said it had 90% less fumes as regular acid. Sounds good, but will it still work as well? Anybody tried it?
Epoxy over the perimeter expansion joints?
Flakes: Are all flakes created equal? Is there such a thing as good/better/best flakes? As long as the colors match will the flakes you see at the Home Center be the same as the flakes that come in the epoxy kits?
VCT-
Control Joints: These will need to obviously be filled before tile installation. Should I just use a Quickrete concrete patch to fill the joints? Can I get it smooth enough? I have read that even the smallest piece of dirt trapped under the tile will telegraph through. Would a vinyl floor patch work better? would it dry as hard as concrete patch? Backer rod or no backer rod?
Expansion Joints: The joints around the perimeter have that felt type material. Tile over it or just up to it and cover it with a baseboard?
Adhesive: Having a hard time finding the recommended Armstrong VCT adhesive (S-570?). The home centers carry a VCT specific adhesive. Is that acceptable?
I can't begin to tell you how much time I have spent on this site since I found it back in the spring. I would really value the opinions of everybody to help my project turn out as good as some of the garages I have seen here!
Epoxy-
VCT-
