More Whatzits--Can we make this the official Whatzit thread?
real head-scratcher. The yoke is hell-for-stout.n The throat is maybe about an inch deep. The shaft is hollow--about 3/8" ID. The knurled part to the right is a pin vise. The knurled part perpendicular to the shaft does absolutely nothing but turn.
Interesting things, the centering pin or punch on the left hand face intrigues me. Seems like clamping something in the pin vise end, then spinning the handle perpendicular to tighten, would drive that something into the pin or punch. If all that mattered was the punch, there would not be an arch, which implies something got center punched.
Now, if what you clamped was a hollow cylinder, would it then be a hole punch?
Those odd mismatched handles on the perpendicular shaft still intrigue me, gotta think on it more.
Beerhippie
Far NE Oregon
I was thinking the anvil and screw might be for setting hollow rivets or snaps? Maybe the pin chuck held a needle and the spinny part off to the side was a spool for thread? Some kind of leather/sail makers multi-tool?
Anyhow, as soon as the gal that runs the place saw the asking price of $250 on Etsy, she grabbed it back--I suspect that $12.50 has gone up some.
LowOiL
From the amount of whaling upon it's suffered, we had some tough horses and mules back then!
Yeah, it definitely needs those cracks whacked off otherwise one chunk would sling off and cut ya good (don't ask me how I know splitting wood w/ a manual wedge I didn't clean soon enough).
I imagine the horses/mules appreciate not hurting with overgrown toenails.... most of us have had an ingrown toenail or two also...
Beerhippie
Far NE Oregon
Antique vintage tool leather Lock stitch sewing awl and rivet setter from an eBay listing, at $270. Shown with copper rivets with a rove (washer).
Poking thru DATAMP, under trade specific, I did not find it under Leatherworker or Cobbler, or Tailor.
So my guess wasn't that far off.
And, even at $12.50, not something I need.
  • Like
Reactions: RTM
My wife picked this up at a Nevada garage sale. It seems to be a wingnut wrench. IMG_2554.jpegIMG_2555.jpegIMG_2556.jpeg
This wrench she found yesterday seems to be for Champion Brass sprinklers of LA.IMG_2801.jpegIMG_2802.jpeg
More items we found yesterday look to have been made by a machinist for some specific purpose. IMG_2807.jpegIMG_2806.jpeg
An item my neighbor found. A wingnut with a slot and no threads. IMG_2810.jpegIMG_2811.jpegIMG_2812.jpeg
Any guesses on the last few?
nadogail
Coronado, CA
The Wingnut with no threads looks it may be a Spoke Wrench, with a tapered slot to "Sort Of Fit" various sized spokes.
Beerhippie
Far NE Oregon
Sounds like your neighbor is a loose wingnut!
The machinist-made tools look they're for a bezel of some sort? Scale?
Correct
Yep Spoke wrench - probably for bicycles (rather than motor cycles)
Heh, responded and didn't hit "Post"
That last one is a spoke wrench (aka "****** grip") - looks similar to the Urich model, but a wee bit different.
Blue Chips
Maine
Ooh, I got some whatzits right here:
They look simple enough but heck if I know what they're from.
Seems to me I saw plenty of those back in the '70s. IIRC, they were commonly used under manifold bolts.
That would be my take on it as well. To me they look like plain and flanged varieties of spherical washers, such as used to secure exhaust and intake manifolds, often found on straight 6s and straight 8s. The idea was to evenly distribute the clamping pressure on uneven, mismatched, misaligned, or slightly angled surfaces, hopefully without breaking off any of the cast-iron mounting bosses or tabs. My 1954 Dodge M37 manifolds are mounted with spherical washers.
Spherical washers are also known as 'leveling washers,' and are supposed to have two parts, male and female.
Example: https://www.mcmaster.com/products/washers/washer-type~spherical/
Skyman
Central Maryland
My admittedly hazy memory is that the set in this photo was used on MOPAR slant six manifolds. Might have also been used on other makes. Come to think of it, looks like traces of Chevy orange paint on a few of them.
pcrov
Ontario, CA
Those have a flat side each, these are concave on one side and convex on the other (aside from the two brass bushings.)
Blue Chips
Maine
Hmm. In that case, it's a bit harder to speculate about their use.
There are a lot of variations on spherical and conical washers and nuts, and they can be used for quite a range of applications. For example, instead of a two-piece male-female spherical washer, a female spherical washer can coupled with a nut that has a male spherical base. These nut-washer combinations can be spherical or conical.
Here's an example of a brass conical washer coupled with a conical nut:
As to the concave/convex triangular pieces in your photo, I'm not sure about their use, but here's one possible scenario: They 'might' have been used between the mounting flange of an exhaust manifold and the mounting flange of an intake manifold, with the mounting stud in the position of the arrow in the image below, in which case a spherical-bottom nut could have been used in conjunction with them. It's cheaper to stamp a part like that than to machine it, and IF the gap between the flanges is wide enough, the convex side would simply protrude down between the flanges without touching anything. (The triangular pieces in your photo would have required a wider gap than the gap in the image below.) Because the thicknesses of manifold flanges are not always equal, a spherical or conical washer or washer-nut combination would allow for differences in thickness while more or less equalizing the clamping pressure on both flanges.
You might try taking a few photos of the individual pieces and do a Google image search on them.
Edit: I should add that there are also various ways of stacking spherical washers and combining them.
Beerhippie
Far NE Oregon
Oh gawd! That set-up just brings back too many bad memories... trying to find a wrench that fits in there... percolating carburetor in the middle of the desert... etc... drain plugs on the intake manifold... there's something ain't right about it.
pcrov
Ontario, CA
I didn't have much luck, but it's easier when you have an idea of which rabbit hole to follow. Here's some singles in case anyone wants to have a crack at it.
IMG_20250616_185527756.jpgIMG_20250616_185522513.jpgIMG_20250616_185516477.jpgIMG_20250616_185535679.jpg
(The background grid is half-inch squares, by the way.)
bcschief
Crescent City Florida
Chrysler slant six uses that style nuts and washers and the bat wing washers.
I found what looks to me like some kind of adjustable pin spanner at the flea market today. I am not 100% certain of that. No markings. I have hook spanners, pin spanners, and adjustable hook and pin spanners, but I have never seen one quite like this design, with a thumbnut slider, or with the pins in line with the handle. It's also not very heavy duty. Does anyone more precisely recognize it?
Nope and I was surprised when looking at the pics up close that it was not shop made!
No, but I'd be inclined to go down the watch tool rabbit hole first, rather than a mechanic's tool. The Benj Allen catalog didn't show one, so maybe not.
Agree watch, or other fine instruments. meaning measurement or electronic analysis gear or similar.
Thanks, guys. Makes sense. The teats are 1/16" in diameter and the range is 1/2" to 1-7/16" center to center teat. This example looks older to me, just because of the materials and wear, but it's interesting how consistent the design is. It seems like a lot of tool for a watch. I wish I had one just to try it! (I don't wear watches.) But I'm sure I'll find a use for it. Ratchets, for instance.
