tankwilson
Ok guys getting ready to build a 32 x 30 garage in souther Iowa.
In floor heat or hanging gas heater?
thanks
matt
thanks
matt
if you can afford it ........ in floor heat. Probably should do it even if you can't afford it !!
Now being in Iowa you may not need the benefits that in floor offers in the really cold but that will be up to you.
thanks
matt
I love my in floor heat. I think it's the absolute best way to heat a building period. But, being a glass half-full kind of guy, I will point out the downsides of in floor radiant compared to forced air gas heat.
1. It's more expensive to install. Say roughly 5K vs 1K in round numbers.
2. It doesn't have the recovery. It's great for a building heated 24X7 all winter, but would be almost useless in a situation where you keep the garage unheated until you are ready to work in the building.
3. The cheapest way (BY FAR) to heat a garage (in a non-commercial setting) is to only heat it when it will be occupied. For a hobbiest, that might be an hour or two 3 nights a week and all day on Saturday for instance. GFA is great at that type of scenario. Radiant heat ***** at that.
The biggest advantages to radiant are that it is much quieter than forced air and provides a nice even heat which is more comfortable than having hot air blowing on you from a vent or radiant tubes that are making your head hot while your feet are still freezing.
If money is no object....or you need/want to heat 24X7, radiant is the berries.
I love mine.
Phil
I love mine.
Phil
My propane supplier told me he loves in floor heat....because of it's lack of efficiency. He said even with insulation you are trying to heat the ground. Hot AIR rises, but convection works in all directions including down. Plus, no set back on in floor. He said he has never seen a situation where the in floor used less gas than conventional heating. Just passing that along. If I were going to be in the shop every day for most of the day, in floor might be the way for me. That just isn't my reality.
